Toggle Content Quick Search
Toggle Content Donations
We need your help! Every little counts!
So far we have raised £5.00 this month using this button!
Latest: notrix
New Yesterday: 7
Overall: 8794
Online Now [34]:
Visitors: 22
Bots: 2
Members: 10
Today: 17215
Total: 30988090
Forums › The Car › 206 Problems › Fault Code Reading, Key Programming & FAP Removal
Go to page 1, 2, 3 ... 9, 10, 11  Next
Reply to topic Printer Friendly Page  View Previous Topic View Next Topic
PostPosted: Sat Oct 30, 2010 7:45 pm Up
Trade Rating: +64
Fault Code Reading, Enabling/Disabling ECU & BSI options, Key Programming and FAP / DPF Removal Available using Dealer Software!
I am offering fault code reading to people for £20.
For FAP/DPF Removal it would be £60. This includes removing FAP from ECU and BSI and deactivating the DPF ECU. Then you just need to go to a exhaust place and basically get a de-cat pipe.
What I will do
I will firstly code read the car. I will then clear any faults you want execpt airbag faults. Then I will code read it again after the car has been running for 2 mins or so to see if any have come back.
What can I code read?
I now have software and hardware that enables me to fault code read pretty much any car now. Generally, I am able to read the same ECU's as I can with Peugeot, Citroen, BMW, Vauxhall, Rolls Royce and Mini.
I am able to access the following brands of vehicles.
Peugeot
The fault code reading will be using Peugeot Dealer software and will cover:-
- BSI
- Engine ECU
- ABS and/or ESP ECU
- Air Condtioning ECU
- Sun Roof
- Auto Transmission Control Unit
- Airbags
- LPG
- Navigation Control Unit
- Multi-function Display
- DPF (FAP)
- Service Indicator
- COM 2000
- Plus Many More!!!
subject to you having the required ecu's
What I can give you information on
Heres a few things that may interest you on what I can do and maybe even change for you.
BSI:
- Identification
- Fault Reading
- Fault Clearing
- Driver control tests (basically testing the stalks and com2000)
- Saftey tests (recognising if doors are open or not)
- Vehicle immobilisation (engine ecu response, number of keys, number of remote keys)
- State of outputs
- State of inputs
- Actuator tests (buzzer, de-icing, demisiting light, engine check ecu resupply, door locking/unlocking output, screen wipers, indicators)
- Configarations (note this is based on my none plaxed car door open warning lamp, vehicle speed information, rain sensor, auto transmission safety warning, central locking, high frequency remote control)
Engine ECU
- Identification
- History (previous faults cleared)
- Fault reading
- Fault clearing
- Principle parameter reading (engine speed, camshaft/crankshaft synchro, measured fuel pressure, difference between fuel pressure & recommended fuel pressure, diesel pressure regulator OCR, injected flow set point, injector flow correction, injector voltage, EGR valve electrovalue, EGR throttle electrovalue, diesel pressure regulator current, pre-injection advance, main injector advance, turbo pressure, 3rd pistion deactivated, atmospheric temp, coolant temp, air temp, fuel temp)
- Electrical Information (engine speed, battery voltage, supply voltage to sensors, injector voltage, pre/post heating relay, AC cut request, fan high\low relay)
- Driver Information (engine speed, vehicle speed, accelerator pedal position, gear ratio, auto transmission gearbox recognision, main brake switch active/inactive, cruise control active/inactive, injected flow set point)
- Various actuator tests
if you require any Peugeot that does not have the standard 16-pin or the 2-pin connector, please let me know before hand as I may not be able to code read it
Citroën
I also have dealer software for Citroën and can do the same as I can with Peugeots and can do the following models
I also have dealer level software for Vauxhall, BMW, Mini and Rolls Royce
I can code read, code keys and make alterations on the following.
Vauxhall
Agila A, B
Corsa C, D
Tigra A, B
Meriva
Astra F, G, H, J
Zafira A, B
Insignia
Vectra C, Signum B
Captiva
Antara, Captiva MAXX
Vivaro
Morvano
GT
Speedster/VX220
Combo C
Omega B
Frontera B
Campo
Monterey
Sintra
Currently only have the 16 pin connector for these, and also to change some settings in the ECU's you need the CAR PASS code
BMW
E31, E34, E36, E38, E52, E39
E46, E53, E60, E63, E64, E65
E66, E67, E70, E71, E72, E83
E85, E86, E87, E81, E82, E88
E90, E91, E92, E93
I have the EOBD and OBDI connector for these
Mini
R50, R52, R53
R56, R55, R57
Rolls Royce
RR1, RR2
In Depth Scans of the Following cars
Alfa Romeo
Audi
Autobianchi
Cadillac
Chevrolet
Chrysler
Dacia
Daewoo
Daihatsu
Fiat
Ford
Honda
Hyundai
Jaguar
Kia
Lada
Lancia
Land Rover
Lexus
Maybach
Mazda
Mercedes
MG
Mitsubishi
Nissan
Porchse
Proton
Renualt
Rover
Saab
Seat
Skoda
Smart
Ssangyong
Subraru
Suzuki
Toyota
Volkswagen
Volvo
Zastava
These are currently all subject to having the 16 pin OBD/EOBD port, contacct me for more details
Other Services
I also offer FAP/DPF removal.
I also have a piece of kit that allows me to do a mobile dyno. It only works on EOBD compliant vehicles. Ask me for more details.
I am able to get Peugeot and Citroen Radio codes, along with a couple of other models. Ask for more information.
Few examples what I have recently configured on some multiplexed 206's
- Hazards flash under sharp braking
- Anti Hijack
- CD changer
- Crystal headlamps
- Trip computer
- Rear wiper when reverse gear is selected (when front wipers are on)
- Running lights
- Turned FAP off [needed if you are having FAP mapped out]
Key Programming
If you require another key, I can also reprogram this as long as you have the 4 digit security code. I can get you this for FREE if you don't have it, if I am selling you a transponder or coding you a key, otherwise I charge £1.
I am located in the Sheffield, but I will travel upto 20 miles to you and that will be included in the price.
However distances outside the 20 miles will be charged at 60p a mile one-way.
Any questions, feel free to ask either by:-
- posting
- PM
- Tel: 0203 239 5172
Thanks,
"Don't learn the tricks of the trade. Learn the trade."
"Never look down on a man, unless you are helping him up" - Jesse Jackson
View user's profile Send e-mail Visit poster's website MSN Messenger Yahoo Messenger
PostPosted: Sat Oct 30, 2010 7:51 pm Up
Wow. Well done Lee.
How much would it be to come to Athens?!
1.4i, 2001, TU3JP, 3-door, China Blue
PostPosted: Sat Oct 30, 2010 7:54 pm Up
Staff - Howey
Trade Rating: +30
V9977 wrote:
Wow. Well done Lee.
According to google maps around £1020! Laughing Razz
1999 XS, China blue
1989 1.6 205 GTi Alpine White
PostPosted: Sat Oct 30, 2010 7:55 pm Up
Stickered for you Lee
Nice one for offering this
PostPosted: Sat Oct 30, 2010 7:58 pm Up
Trade Rating: +64
V9977 wrote:
Wow. Well done Lee.
Pay for my flight and i'll do it free Laughing
Can't stand this hole Laughing
Antix
PostPosted: Sat Oct 30, 2010 8:00 pm Up
Custom - Red Stars
Lee - will you be attending the RSTuning meet in December?
(with your laptop) Wink
EDIT: will this delete faults as well as read them?
Staff - Howey
Trade Rating: +30
Just hide it from Paul! Laughing
1999 XS, China blue
PostPosted: Sat Oct 30, 2010 8:01 pm Up
Trade Rating: +64
Cheers.
Will post a few pictures up with what type of results I can get, with all the faults on my car which i never knew I had Confused
PostPosted: Sat Oct 30, 2010 8:03 pm Up
Trade Rating: +64
I'm not sure, depending on if I'm free or not.
Yeah I can clear faults as it is dealer level software, should actually put that in the original post Laughing
I won't clear airbag faults tho, unless I've got a guarentee it's been repaired, simply because of the dangers tbh
PostPosted: Sat Oct 30, 2010 8:05 pm Up
How about adding things like Auto Lock, Auto Rear Wiper??
PostPosted: Sat Oct 30, 2010 8:08 pm Up
Trade Rating: +64
I've not really had that must time to play about with it. But I have noticed BSI configurations, and I will have a look on my car to see what I can do before I do anything on other peoples.
I can't do BSI updates tho, due to me not working for Peugeot
I've also got Lexia for Citreon cars, but I need to install that.
I'm also trying to get some other software which will allow me to do standard EOBD scans on other cars.
PostPosted: Sat Oct 30, 2010 8:10 pm Up
Sounds good Lee can see you getting a lot of people taking this up, as most garages will charge a hours labour for this
PostPosted: Sat Oct 30, 2010 8:14 pm Up
And if the car is a non-runner you have to somehow get it TO the garage
which makes these rates seem excellent tbh.
PostPosted: Sat Oct 30, 2010 8:17 pm Up
Trade Rating: +64
As long as the igntion works, then it should scan because then there is power going to the OBD port
Big_Rich180
PostPosted: Sat Oct 30, 2010 9:52 pm Up
Could you do mine mate?
Reply to topic Printer Friendly Page  View Previous Topic View Next Topic All times are GMT
Page 1 of 11
