Latest: Kifi69
Overall: 17183
Online Now [531]:
Visitors: 530
Today: 40680
Total: 144332279
Forums › The Car › 206 Problems › Comm2000 unit
Comm2000 unit
Ben.M
PostPosted: Sat Jan 29, 2011 3:49 pm Up
I have the indicator problem with my comm2000 unit, I plan on getting another one from the scrappies but first I need to know how to take it off and put it back on...does anyone know how to do this as there is not a 'How to' for it??? :/
Thanks,
Ben.M
PostPosted: Sat Jan 29, 2011 3:52 pm Up
I'll take the faulty com. Let me know how much you want for it via PM.
D/C the battery in the correct way, take off the shroud and its pretty straight forward from there.
Kazza67
PostPosted: Sat Jan 29, 2011 4:04 pm Up
Thanks Lee, your a bit far away so will have to get my local mechanic to fault code it for me next week. How complicated are cars nowadays????
Thank you
skard
PostPosted: Sat Jan 29, 2011 4:15 pm Up
the general jist of it on a multiplexed car is - park car with wheels straight, disconnect battery using the BSI shutdown procedure, wait some time for airbag electrics to discharge (10-20mins), pop off airbag with a flat screwdriver (it's at the rear), take off airbag and disconnect wiring carefully, use a T50(?) torx bit and a bit of brute force to crack off the steering wheel bolt, undo wheel (being careful not to pull it towards your face at this point so leave bolt in for a few threads). at this point you can swap out the comm unit and carefully refit in reverse.
Ben.M
PostPosted: Sat Jan 29, 2011 7:48 pm Up
Great, thank you Very Happy
Ben.M
PostPosted: Sun Jan 30, 2011 6:39 am Up
Any garage that has a EOBD/OBD-II code reader will be able to read your powertrain codes [P Codes]. It costs anything upto £60 depending on the garage [excluding dealers].
