Posted: Wed Mar 02, 2011 7:15 pm |
Trade Rating: +64
Take it forgranted then that you checked all the fuses with you noticing fuse 5 was broke?
If the fuse it fine and the main beam is working, you've either damaged the bulb holder/connector or there's a break in the wiring from the short circuit
| "Don't learn the tricks of the trade. Learn the trade."
"Never look down on a man, unless you are helping him up" - Jesse Jackson
Posted: Wed Mar 02, 2011 7:21 pm |
Yeah I checked all the fuses under the bonnet and they were all fine .. The plastic connector that the bulb connects into is damaged it's melted . It was like that when I bought the car and the light was working .. But the plastic holder itself has kinda fell to bits but surely if you plug the spade connectors to the bulb it would still work ?
| black 206 hdi s with gti wheels and spolier ...my other cars an evo  | |
Posted: Thu Mar 17, 2011 4:44 pm |
I have the same problem, did you manage to fix yours?
Posted: Wed Mar 23, 2011 7:23 pm |
i found fuse 11 (10 amp) was blown in the fuse box in next to the car battery. i was shouting at my morrettes wondering why the high beam wasnt working on my drivers side. "I kept saying to myself it cant be a fuse, why would they fuse 1 bulb"
Guess what it was a fuse...
just pull all fuses out one by one and check them. MAKE SURE YOUR CAR'S batttery is disconnected safely
