Posted: Tue Mar 08, 2011 4:53 pm |
is it easy job? wot do i need plus how do u do it? please yep as got air in brakes
Posted: Tue Mar 08, 2011 4:59 pm |
u need a spanner, a friend to help. also a bleed kit or a bit of pipe and a jaw of brake fluid,
then you fill up brake fluid res, leave the top off, put the pipe ./ bleed kit on the bleed nipple. and the pipe going in to a jaw of oil, ghet your friend to pump the break 3 or 4 times and hold foot down as you undo the bleed valve and look for bubble appearing in the jaw of oil. then tighten up and then your friend can release break, do this untill the break feels solid on both sides.
| *DEAD*206 Gti 138
Toyota Celica 140 | |
its a 2 person job, basically one has to undo bleed nipples at each wheel while the other pumps the pedal, once the airs out you do the nipple up whilst fluid is being pumped out to prevent air getting sucked back in
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Tue Mar 08, 2011 5:09 pm |
[quote="leigh_boy".. and a jaw of brake fluid, ..[/quote]
not recommended..
| Member number: 36
BREAKING: 2001 Black GTi 138
Click Here | |
Posted: Tue Mar 08, 2011 6:19 pm |
Gunson Easibleed makes the job simple
Posted: Tue Mar 08, 2011 6:26 pm |
nothing wrong with the way i do it
| *DEAD*206 Gti 138
Posted: Tue Mar 08, 2011 6:27 pm |
| MrBSI wrote: |
Gunson Easibleed makes the job simple  |
I can vouch for that
Posted: Tue Mar 08, 2011 6:29 pm |
| leigh_boy wrote: |
nothing wrong with the way i do it  |
Takes far to long & you risk ruining the master cylinder seals if the person pressing the BRAKE pedal goes full stroke
Easibleed makes it a simple one person operation
Posted: Tue Mar 08, 2011 7:18 pm |
just out of interest, how does it work?
Posted: Tue Mar 08, 2011 7:27 pm |
Basically you fill the reservior and the bottle with brake fluid, then one pipe goes on a cap with fits on your reserviour, then another pipe fits over the bleed plug. The bleed plud one has a switch similar to what goes on your tyre to blow them up, you click that into place and it does its thing.
Posted: Wed Mar 09, 2011 4:38 pm |
You MUST drop the tyre pressure down to around 10 psi on the tyre suppling the easibleed with air else you can damage the seals in the master cylinder
Posted: Fri Mar 11, 2011 12:00 am |
oops :S
Posted: Sun Mar 27, 2011 4:10 am |
Does anyone know where to get replacement bleed nipples set of 4?
Also i plan on changing the brake fluid when having my axle swapped, how much fluid would i require?
Cheers
| 206 3dr 1.4 GLX modified slightly, Green Induction kit, Lowered 35mm on full Gmax kit, GTI rear axle (still to be lowered to match the front again), 17" AEZ xylo alloys 205/45/17, 4" Savage back box,
More to be done in the future. Searching for good priced parts. | |
Posted: Sun Mar 27, 2011 8:40 am |
| Coolspot wrote: |
Peugeot / Citroen main dealer.
Place that overhauls brake hydraulic part's.
Posted: Sun Mar 27, 2011 10:12 am |
| Coolspot wrote: |
Cheers |
About £6 each from stealership (0000442813) and shouldn't need more than a 1 litre (to allow for bleeding) bottle of DOT4 fluid
