Toggle Content Quick Search
Toggle Content Donations
We need your help! Every little counts!
So far we have raised £5.00 this month using this button!
Latest: notrix
New Yesterday: 7
Overall: 8794
Online Now [24]:
Visitors: 9
Bots: 2
Members: 13
Today: 19367
Total: 30990242
Forums › The Car › 206 Problems › Removing the struts
Removing the struts
Reply to topic Printer Friendly Page  View Previous Topic View Next Topic
PostPosted: Tue Apr 05, 2011 2:38 pm Up
Trade Rating: +86
Thought I could do this within a day, was I wrong..
I've removed my struts several time but the shocks have shortend piston rods so it's easy to get them out. I'm now doing it on standard shocks and there just isnt enough room, the hub is as low as it can go and the strut is still pressed against the top. I don't understand am I missing something?
Arrow XSI WIP
Arrow GTI 137/138/180 parts for sale
PostPosted: Tue Apr 05, 2011 2:44 pm Up
Last time I tried the bar I was using to lever the hub shattered & I got a 1" cut on my forehead Sad
Got a scar to show for it.
l_jacka
PostPosted: Tue Apr 05, 2011 2:48 pm Up
Have you disconnected the lower arm from the hub?
Looking to buy my first peugeot 206
PostPosted: Tue Apr 05, 2011 3:13 pm Up
Trade Rating: +86
Ouch Sad didn't realise they would be this much of a ball ache.
I've taken undone all the bolts and removed the steering ball joint but this didn't give any more clearence, I haven't taken the hub off I thought it would be a bit of an overkill. I know when mine got lowered it was removed without that happening and I've done it since on shortend shocks just by undoing the 3 bolts at the top, the one at the bottom and the drop link.
Arrow XSI WIP
l_jacka
PostPosted: Tue Apr 05, 2011 3:25 pm Up
You need to just disconnect the lower arm from hub, The hub wont be removed fully as it will be held in place by driveshaft and the steering rod, it easy getting the strut out but It a ball ache getting the standard sturuts back in lol
PostPosted: Tue Apr 05, 2011 3:33 pm Up
You can take standard ones out without lossening hub off ball joint by standing on hub Wink
But taking off ball joint is soooo much Easyer Smile
Old Project:
Click HERE
NEW Project : Click HERE
Member : 32
So lazy i get SIRI to type for me Razz
PostPosted: Tue Apr 05, 2011 3:50 pm Up
Trade Rating: +86
Yeah sorry phrased that wrong, alright cheers will have a go tomorrow Smile
Don't fancy standing on it to be honest Laughing
Just bolt out and in theory they should seperate? My guess is I will need to bring a hammer to it.
Arrow XSI WIP
l_jacka
PostPosted: Tue Apr 05, 2011 3:53 pm Up
Why do you need hammer for?
PostPosted: Tue Apr 05, 2011 4:00 pm Up
Trade Rating: +86
If I undo the bolt holding the hub and the lower arm together, I can gaurentee they will still but stuck to each other and won't budge without a lot of force Sad
Arrow XSI WIP
l_jacka
PostPosted: Tue Apr 05, 2011 4:11 pm Up
Hammer wont do anything, you need to use a metal bar like this:
PostPosted: Tue Apr 05, 2011 4:20 pm Up
I sometimes rest a trolly jack bar on an axel stand and were it is on pic above, hit the bar down and it pops out
Old Project:
Click HERE
Member : 32
PostPosted: Tue Apr 05, 2011 4:31 pm Up
Trade Rating: +86
I see, never really used anything like that before sure I will have a bar somewhere though.
What's the best way to get it back on?
Cheers for the help guys
Arrow XSI WIP
PostPosted: Tue Apr 05, 2011 4:37 pm Up
To get it back on I grease it up and push it back in with a trolly jack pushing it up.
How I do it anyway
Old Project:
Click HERE
Member : 32
PostPosted: Tue Apr 05, 2011 4:40 pm Up
Trade Rating: +86
Sounds straight forward, might be an easier said than done thing Laughing thanks
Arrow XSI WIP
PostPosted: Tue Apr 05, 2011 4:56 pm Up
You definately need to remove the hub from the ball joint.
This is the best way of doing it. Needs no effort at all and is therefore less likely to damage anything.
2001 GTi 138, Bilstein B8 Sprint dampers, H&R springs, 21mm Peugeot Sport torsion bars, 22mm rear ARB, Peugeot Sport GP A wishbones, 283mm discs, Goodridge hoses, Maniflow 4-2-1 304 grade manifold and 2.5" system, 200 cell cat, Richard Longman head, 42mm Jenvey Throttle bodies, Piper Ultimate Road cams, Piper vernier pulleys, ACT/Longman/Jenvey carbon fibre airbox, Omex 600 ECU. Vibra Technics engine mounts. Samco coolant hoses, DP Engineering thermostat housing. Very shiny. 2006 VW Jetta 2.0 TDi Sport for everyday use. 2008 207CC 1.6 GT.
Reply to topic Printer Friendly Page  View Previous Topic View Next Topic All times are GMT
