Posted: Wed Apr 06, 2011 10:40 pm |
How do you cure the immobilizer?
Posted: Sat Apr 09, 2011 12:44 am |
If it is the immobiliser shouldn't the display read immobiliser fault
Posted: Sat Apr 09, 2011 12:49 am |
| punk wrote: |
| If it is the immobiliser shouldn't the display read immobiliser fault |
The display's a bit dodgey and doesnt work.
Posted: Sat Apr 09, 2011 9:19 am |
My guess is that 2 pin connector goes to the crankshaft sensor.
If the ECU doesn't see this signal, it wont send thee firing signals to the Spark plugs or the injectors.
The sensor is close to the oil filter and sometimes wont give out fault codes if its defective/not plugged in.
Posted: Sat Apr 09, 2011 1:06 pm |
| AX-Rated wrote: |
The sensor is close to the oil filter and sometimes wont give out fault codes if its defective/not plugged in. |
Would this stop the fuel pump from priming as well?
Posted: Sat Apr 09, 2011 7:47 pm |
if the fuel pump is not priming there is a relay that controlls lots of different things big black 1 under the ecu its about £40 for pug or u could get 1 from a breakers and will probabbly fix the fault.
| *DEAD*206 Gti 138
Toyota Celica 140 | |
Posted: Sat Apr 09, 2011 8:40 pm |
The big relay is about £15.
| 2001 GTi 138, Bilstein B8 Sprint dampers, H&R springs, 21mm Peugeot Sport torsion bars, 22mm rear ARB, Peugeot Sport GP A wishbones, 283mm discs, Goodridge hoses, Maniflow 4-2-1 304 grade manifold and 2.5" system, 200 cell cat, Richard Longman head, 42mm Jenvey Throttle bodies, Piper Ultimate Road cams, Piper vernier pulleys, ACT/Longman/Jenvey carbon fibre airbox, Omex 600 ECU. Vibra Technics engine mounts. Samco coolant hoses, DP Engineering thermostat housing. Very shiny. 2006 VW Jetta 2.0 TDi Sport for everyday use. 2008 207CC 1.6 GT. | |
Posted: Sun Apr 10, 2011 6:48 pm |
Does the big relay control the digital heater control as well?
Posted: Mon Apr 11, 2011 6:41 am |
| Edward wrote: |
| The big relay is about £15. | really??
i bought 1 about 2 years ago now becuae mine packed up and im sure i paid about 35 / 40 from pug, then again might be talking about something different.
| *DEAD*206 Gti 138
Posted: Mon Apr 11, 2011 7:37 am |
| LeeThr wrote: |
| Does the big relay control the digital heater control as well? |
The heaters only blow when the engine is running, but they cam be adjusted without the engine running.
The crankshaft sensor wouldn't affect fuel pump priming.
Posted: Mon Apr 11, 2011 11:20 am |
| AX-Rated wrote: |
| LeeThr wrote: |
The crankshaft sensor wouldn't affect fuel pump priming. |
I know they only run with the engine running, I mean the whole control unit has gone dead so you cant adjust it. Im asking if its that big relay that controls that as well?
