Latest: tc.206
Overall: 17147
Online Now [129]:
Visitors: 128
Today: 3732
Total: 116423906
Forums › The Car › 206 Talk › The bumper guide to budget modding!
Dabamash
PostPosted: Thu Apr 07, 2011 1:05 pm Up
Staff - Daba
So, the economy sucks, David Cameron is bleeding your wallet dry to pay for his multiple houses and cars and petrol prices are soaring.
On the other hand, your car looks like crap.
So here's the bumper guide to modifying your 206 on a budget!
1. Debadge the rear.
It's an old one and a good 'un and can make your car look much sleeker for a budget of exactly £0.
There's a how-to HERE.
Obviously, there's the added cost of cleaning materials and T-Cut and stuff, but if you're lucky, you won't need it Wink
2. Pull off your B pillar vinyl
Yeah, there's much debate as to whether this looks good or not, but I did it and I think it looks better.
Simply get a hairdryer and wave it over the black vinyl on your b pillar for a while, then pull it off. Do a small part on the inside of the door first to make sure that your car is painted underneath.
Here's a how-to
3. Aero Wipers
A small mod and slightly more costly than the last two. Replacing your standard wipers with aero style wipers can greatly modernise the front of your car, along with the added visibility in the rain. Many people suggest Bosch Aerotwins as being the best quality for your money.
4. Colour Coding
Colour coding is standard on higher end/newer models of 206. Reason? it looks great! This can be done very cheaply and will improve the look of
your car enormously.
just remember to take your time Wink
5. Front badge painting
Since you've just colour coded you car, why not paint your front badge as well? Or you could paint it black, or any colour you want to be honest Wink
Here's a picture of Crossie's car to demonstrate (sorry Crossie lol)
6. Light Masking
This is a forum favourite. Originally done by Valeo, the Phase 2 crystal headlights with black innards have become very popular in the modding scene. As such, when Valeo stopped making them, people started making their own!
There's a how-to for this as well HERE
You can do your foglights to match if you are so inclined, and there is another how-to HERE to cover that. Smile
7. Stickers
Again, stickers are like marmite, you either love them or hate them. I, personally, have a 206info sticker over my front headlight.
Stickers are cheap and easy to do, so they're worth considering
8. Door card trim
Get your hands on some cloth and retrim your interior. It can make an old, faded interior look much more luxurious and can be done on a fairly low budget.
Leather, suede, leopard print, pink and furry, your choice Smile
How-to: HERE
9. Caliper Paint
Everyone knows that sporty cars have big red brembo brakes. So you might as well make your crappy 1.1 look sporty and give the old calipers a lick of paint Wink
I believe Hammerite is generally considered a good choice of brand.
You might as well experiment with colours. The info community loves a bit of originality Wink
10. Change your interior lights colours
Changing your dial lights from orange to something a bit more jazzy can improve the look of your car at night and make you feel like you're drive a Ferrari, rather than a piece of French s**t.
Mr Helsop has done a great how-to to guide you through it HERE.
It's worth noting that if you have a pre-plex pug, you can simply buy a lockwood dial and not bother faffing about with LED's from HERE
While you're at it, you can also change the main interior convenience light with something a bit brighter like an SMD tower to replace the standard bulb.
11. De-wiper your rear
This is another simple mod that looks great when done in conjunction with a debadge.
Tom has a how-to HERE to help you out
12. Phase 2 boot strip
This is simply a bit of plastic, but it can make the back of your car look a lot more tidy if you have a Phase 1. Have a look at the next picture in the thread to see what one looks like. You can get these fairly cheaply from scrapyards, or occasional sellers on the forum. You'll need a bit of luck to find these at a scrapyard though.
13. Phase 2 Rear Lights
Again, this is an upgrade from phase 1 to phase 2. Keep an eye out for phase 2 lights in the For Sale section, as the often come up below £40. They are also really simple to fit, which is a bonus.
Obviously, unless you can find these at a scrap yard, this is a cheap, but probably not a bargain basement mod.
14. Interior Spraying
Spraying interior components, such as the door handles, central console, vents etc is often a popular mod. If you have some paint spare from colour coding, you could colour code the interior or engine cover as well.
15. Wraps
The cost of this is debatable and variable, but wrapping parts of the interior or exterior, such as wing mirror caps with carbon 3M DiNoc can be a great way of adding that sporty flair.
16. Sidelights
Smd Sidelights are a great way of adding that modern twist to the front of your car as they remove the yellow light and replace it with a bluer/whiter light. There are also much brighter than standard halogens, so there is an added safety aspect.
You can get a huge range of SMD sidelights. You'll need 501 lights to replace your old sidelights.
They come in single SMD, square SMD, SMD towers, multiple flat SMDs etc. However, the best replacement for your old sidelights are 9 SMD towers. These can usually be found on eBay for less than a tenner.
This is due to the fact that they are small enough to fit in the sidelight hole, but give full 360 degree light output without any loss of brightness
I recommend these
17. PH2 washers
If you have a phase 1 206, your window washer jets only spray out a single jet of water. Phase 2 jets mist your whole window with water instead. They look a lot cooler when spraying and also wash your window more efficiently. The best bit: You can pick them up for free from a scrapyard.
They are also cheap to buy and really easy to fit.
Well, that'll do for now. If you can think of anything obvious that I've missed, whack it in the comments and I'll add it to this post.
Hope that helped Wink
PostPosted: Thu Apr 07, 2011 1:06 pm Up
OI! My guide for removing rear wiper! Wink
Dabamash
PostPosted: Thu Apr 07, 2011 1:07 pm Up
Staff - Daba
I'll add it
PostPosted: Thu Apr 07, 2011 1:10 pm Up
Dabamash wrote:
I'll add it
Good dog! Wink
Haha, now what can I do for £0.20p threads will be no more! BOOMM!!!
(Seriously, good post)
Ali_H
PostPosted: Thu Apr 07, 2011 1:12 pm Up
tomd0801754 wrote:
Dabamash wrote:
I'll add it
Good dog! Wink
You don't believe that any more than the rest of us...lol
kurtis wrote:
Dabamash
PostPosted: Thu Apr 07, 2011 1:13 pm Up
Staff - Daba
tomd0801754 wrote:
Dabamash wrote:
I'll add it
Good dog! Wink
Lol, no they won't. People don't read
PostPosted: Thu Apr 07, 2011 1:17 pm Up
Ali_H wrote:
tomd0801754 wrote:
Dabamash wrote:
I'll add it
Good dog! Wink
I can but dream! One day Info will be erradicated of stupid questions and silly people...
Dabamash
PostPosted: Thu Apr 07, 2011 1:19 pm Up
Staff - Daba
tomd0801754 wrote:
Ali_H wrote:
tomd0801754 wrote:
Dabamash wrote:
I'll add it
Good dog! Wink
When it shuts down Wink
PostPosted: Thu Apr 07, 2011 1:29 pm Up
www.boyracerguide.co.uk/guide.php
Jay794
PostPosted: Thu Apr 07, 2011 1:33 pm Up
This is a great guide Daba, should stop a few "modding on a budget" threads. What about a phase 2 boot strip and phase 2 rear lights? They're relativity cheap from a scrapper?
Dabamash
PostPosted: Thu Apr 07, 2011 1:34 pm Up
Staff - Daba
Yeah, I suppose they are fairly cheap. I'll stick them in
PostPosted: Thu Apr 07, 2011 1:35 pm Up
Depends your classification of cheap... £30 for each 2nd hand of here, and you have to be pretty lucky to find them in a scrapyard...
j3xoc
PostPosted: Thu Apr 07, 2011 1:40 pm Up
pull off your b pillar vinyl
does this actually look good? and does it leave much glue ect. after pulling off? on your it looks great because the blue really stands out but mines gold and not sure if it will or even what's behind that horrid black stuff lol
Dabamash
PostPosted: Thu Apr 07, 2011 1:42 pm Up
Staff - Daba
The glue is a bit of a b***h to get off, but I managed it without even using a hair dryer. I imagine heating it first would get it off without any residue.
If you don't like it, you can probably re-wrap it with gloss black vinyl or something
PostPosted: Thu Apr 07, 2011 1:43 pm Up
No glue residue.. Smile Well, not after a quick wash. Smile
Before:
After (Ignore every other single mod) :
Page 1 of 5
