Posted: Fri May 20, 2011 6:23 pm |
So.. i was driving about before when the car decided it wanted to fill itself with smoke! So i pulled over and opened the windows and called greenflag as there was no fire or anything. Pulled the handbrake cable up and the bottom of the lever was sparking :/
So i quickly disconnected the battery and had a look at the cables from inside and all of the plastic/rubber sheath had melted off and the cables were stupidly hot
i have looked at all the cables around it and cant find anything and myself, the greenflagman, my dad and my dads ex AA boss are all stumped..
Any help or advice would be massively appreciated!
Posted: Fri May 20, 2011 6:26 pm |
Trade Rating: +64
Short circuit. Either loose earth or +12vs touching each other. There is a earthing point under the center console
| "Don't learn the tricks of the trade. Learn the trade."
"Never look down on a man, unless you are helping him up" - Jesse Jackson
you are saying the handbrake cable has melted?
Posted: Fri May 20, 2011 6:30 pm |
has something got on the exhaust ?
Posted: Fri May 20, 2011 7:02 pm |
I've had the centre console off and all the wires are intact with none of the insulation cracked or broken and the earths seem pretty solid, ill take all the earths off tomorrow and give them a clean with wire wool
Yes the plastic handbrake sheath has completely melted due to the heat in the cable, it stunk and filled the car, its still in my throat :/
It only seems to spark after a few minutes of the battery being connected
Posted: Fri May 20, 2011 7:03 pm |
| cartoonhead wrote: |
| has something got on the exhaust ? |
nope its all clear and the outside of the cables near the exhaust are fine its just after they go inside where it gets a bit grim
Posted: Fri May 20, 2011 7:41 pm |
Sounds like an electrical short, wonder if somethings trying to earth itself back through the handbrake cable?
Posted: Sat May 21, 2011 1:08 am |
i'll have a ganders later and get back to yous if i sort it or if i run out of ideas! everyone iv asked so far has said "i've never seen that before" lol
Posted: Sat May 21, 2011 1:17 am |
Have you checked the cig lighter connections?
I would think a fuse should have blown if it was a dead-short.
If you've melted the loom that's bad news. Otherwise should be OK.
| 1.4i, 2001, TU3JP, 3-door, China Blue | |
Posted: Sat May 21, 2011 2:45 am |
| MrBSI wrote: |
Sounds like an electrical short, wonder if somethings trying to earth itself back through the handbrake cable?  |
this.
i've had stuff like this happen at work before
Posted: Sat May 21, 2011 9:01 pm |
Cheers guys the earthing problem seems to be the thing everyone is saying
What would be the best way to go about sorting it out? clean the existing earths and put another connection from battery -ve to the chassis?
Posted: Sat May 21, 2011 9:03 pm |
| V9977 wrote: |
If you've melted the loom that's bad news. Otherwise should be OK. |
nope i checked everything and nothing seems melted or damaged in any way and no fuses have blown
Posted: Sat May 21, 2011 9:13 pm |
When you release the hand brake are the rear wheels rotating freely?
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Sat May 21, 2011 9:15 pm |
they were but im sure it wasnt at one point because the passenger side drum was really hot after i got home, more so that the driver side but i jacked it up and the wheel turned freely :/
Posted: Sat May 21, 2011 9:25 pm |
If nothing with electrical.check cable linkages down to drums.there might be kinda friction somewhere making the cable hot!
