Posted: Sun Feb 05, 2012 3:35 am |
As above not worth the effort and money to fix that, Better scrapping and buying another
Oh that has not gone well. I have bent wishbones before but never totally snapped one. They are pretty thick. Must have hit it hard.
Posted: Sun Feb 05, 2012 9:14 am |
How can anybody say that's not worth repairing? Wishbones are designed to break, subframes are supposed to bend to save the body from damage. The photos don't show enough detail.
| 2001 GTi 138, Bilstein B8 Sprint dampers, H&R springs, 21mm Peugeot Sport torsion bars, 22mm rear ARB, Peugeot Sport GP A wishbones, 283mm discs, Goodridge hoses, Maniflow 4-2-1 304 grade manifold and 2.5" system, 200 cell cat, Richard Longman head, 42mm Jenvey Throttle bodies, Piper Ultimate Road cams, Piper vernier pulleys, ACT/Longman/Jenvey carbon fibre airbox, Omex 600 ECU. Vibra Technics engine mounts. Samco coolant hoses, DP Engineering thermostat housing. Very shiny. 2006 VW Jetta 2.0 TDi Sport for everyday use. 2008 207CC 1.6 GT. | |
Posted: Sun Feb 05, 2012 9:57 am |
I would have bought three cars by now if you never replaced a few bent parts
Posted: Sun Feb 05, 2012 10:23 am |
| Edward wrote: |
| How can anybody say that's not worth repairing? Wishbones are designed to break, subframes are supposed to bend to save the body from damage. The photos don't show enough detail. |
Not real;y worth it on the value of the car though is it. Plus, who can say the damage you cant see. Its easy to replace parts you can see are broken.
Posted: Sun Feb 05, 2012 10:24 am |
| Edward wrote: |
you are right, but not on a car that only worth GBP 650
Posted: Sun Feb 05, 2012 10:34 am |
| Seabook wrote: |
| Edward wrote: |
you are right, but not on a car that only worth GBP 650 |
It is my first, though, and it's worth more than that in my opinion. What would i be looking at repairing and how much would it cost/
Posted: Sun Feb 05, 2012 10:39 am |
It's impossible to say without seeing everything.
Posted: Sun Feb 05, 2012 11:08 am |
Car needs a complete examination in my opinion if you want keep it,like the engine bay,suspension,centre pipes etc etc. If all those are okay then its all case of replacing the body parts and things you listed.
Apart from the things you listed that needs changing like wishbone,driveshaft.
You should be able to get the wing panel cheap from scrapyard if they have your colour and as for the side skirt maybe but i'm not entirely sure myself if that can be replaced too?? Unless someone can correct me on the side skirt.
Your probably won't be able to find front bumper like yours same colour but you will be able to get one cheap if you scout around on ebay or again check how much the scrapyard sells them.
Posted: Sun Feb 05, 2012 11:28 am |
| kurosagi01 wrote: |
You mean the sill that is welded on.
If you know what your doing with tools it could be an easy repair BUT I wouldnt trust 90% of the people on here to actually know what there doing / make a safe repair.
| eddrj wrote: |
MR BSI is a fu*kin Tw*t its official
Posted: Sat Feb 11, 2012 8:13 pm |
yes the sideskirt is wielded on, so that would need a proper mechanic to cut and replace £150, i have seen lots of 206s with bent side skirts seems to be very hollow behind there
Posted: Sat Feb 11, 2012 8:21 pm |
| Ghosty wrote: |
| i have seen lots of 206s with bent side skirts seems to be very hollow behind there |
206 doesnt even have sideskirts.
You mean the outer sill panel, its perfectly normal for it to be hollow behind there on a car.
| eddrj wrote: |
