Posted: Fri Mar 04, 2011 4:08 am |
It's flashing up that the fuel filter is blocked.. I take it the filter needs changing, where abouts is it located?? Thanks
Posted: Fri Mar 04, 2011 4:23 am |
FAPTASTIC
Why do people keep buying these pieces of s**te
Posted: Fri Mar 04, 2011 4:41 am |
Use the search button at the top, these FAPTASTIC problems have been covered lots on the forum
Posted: Fri Mar 04, 2011 4:58 am |
| MrBSI wrote: |
FAPTASTIC
Why do people keep buying these pieces of s**te  |
'because there ace
Just take the piece of s**t out
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Fri Mar 04, 2011 8:00 am |
| MrBSI wrote: |
Use the search button at the top, these FAPTASTIC problems have been covered lots on the forum  |
Rite well I've searched for my faptastic problem and I can't find ote???
Posted: Fri Mar 04, 2011 8:07 am |
It's not forced to need changing, could be low on fluid or the sensors have gone.
Needs code reading first tbh.
PM a member called paulrushton, met up with him today I turned his FAP off in the BSI and then deactivated the ECU, and he's had a map wrote to over write the ECU coding to take the FAP out. And its working fine now, just needs the physical stuff removing.
Posted: Fri Mar 04, 2011 8:41 am |
Rite ok then so what do you think the best step for me is then?? How do I sort this fap out and how much is it gunna cost? Cheers
Posted: Fri Mar 04, 2011 8:49 am |
Not sure how much he paid for the map, but he uploaded it himself.
I deactivated it in the BSI and disabled the ECU for £20
Then you need to disconnect the sensors, and then remove the particle filter and fit a normal pipe instead.
Posted: Fri Mar 04, 2011 8:55 am |
If I was to just get it mapped wouldn't that work? Thanks
Posted: Fri Mar 04, 2011 8:58 am |
I'm not 100% sure, but if you are disabling it you might as well remove it and then just sell it.
