Online Now [516]:
Visitors: 515
Today: 47106
Total: 152889773
Forums › The Car › 206 Problems › Outside temp read out...
L5_UKS
PostPosted: Tue Sep 27, 2011 5:08 pm Up
Hi,
I've only just noticed after 5 months of owning my car that the outside temp display isnt working :S
Any ideas what the problem could be here?
Thanks Very Happy
Luke.
PostPosted: Wed Sep 28, 2011 12:52 am Up
1st I would do is make sure the plug for sensor is plugged in, on lower end models is a long thin plug behind passenger wirror (were you get to the bolts inside car) i assume 180 Would be same or similar but unsure,
PostPosted: Wed Sep 28, 2011 1:57 am Up
Does the mirror have the little dimple under the passenger mirror?
The wire should be in the normal 3*3 or 5*2 connector
L5_UKS
PostPosted: Wed Sep 28, 2011 12:33 pm Up
Yeah it does i recently changed the passenger mirror because when i brought the car it had a non gti 180 mirror on it, but i dont understand why it dont work as its a simple plug in :S
PostPosted: Wed Sep 28, 2011 12:38 pm Up
Temp sensor might be knackered then
L5_UKS
PostPosted: Wed Sep 28, 2011 12:45 pm Up
Doh Sad sounds like a pain in the a**e job to replace?
PostPosted: Wed Sep 28, 2011 12:48 pm Up
Not too hard
Part Number 6445 F9 @ £27.85
Check the voltage too it first, make sure there is power too it
L5_UKS
PostPosted: Thu Oct 06, 2011 4:11 am Up
What colour wire is the sensor on the mirror? im going to check if the wire's are connected corretly first Smile
