Online Now [883]:
Visitors: 883
Today: 217299
Total: 152608879
Forums › The Car › 206 Problems › replacement rubber ball-joint gaiter for lower susp. arm?
PUGPAUL
PostPosted: Tue Dec 06, 2011 5:42 pm Up
can you buy a replacement rubber ball-joint gaiter for lower susp. arm? It says in the the haynes that it is available seperately; but where from?
cheers!
Peugeot 206 HDi (1.4cc) 'eco' - 2005
PostPosted: Tue Dec 06, 2011 5:44 pm Up
never seen one sold separately
PostPosted: Tue Dec 06, 2011 5:46 pm Up
Not seen one sold for years, most likely can still get them if you find a motor factor with old stock on the shelf.
PUGPAUL
PostPosted: Tue Dec 06, 2011 5:56 pm Up
Oh sh*t - just spent £26 quid replacing a bush on the old arm, now the gaiter has split too! ~ Not prepared to pay out for a new arm on ebay or at dealer on top of the £26 I just forked out. Will a gaiter from a track rod end do instead I wonder?
cheers!
D4NTP
PostPosted: Wed Dec 07, 2011 2:38 am Up
Topgear in doncaster split mine when they lowered it, they got hold of some easily enough
PostPosted: Wed Dec 07, 2011 3:02 am Up
I'm sure I've seen them on Servicebox.
PUGPAUL
PostPosted: Wed Dec 07, 2011 7:14 am Up
WET ON SERVICE box last night and there were no parts diagrams for suspension? (everything else - yes!)
cheers!
PUGPAUL
PostPosted: Wed Dec 07, 2011 7:16 am Up
I'll try my local factor then, and JCT...
CHEERS!
PostPosted: Wed Dec 07, 2011 8:12 am Up
Servicebox definately has suspension diagrams.
gazza82
PostPosted: Wed Dec 07, 2011 10:52 am Up
If the ball joint cover has been split for any length of time, then it's likely that grit has got in and the grease leaked out, which is now causing wear on the joint itself. It's sometimes a waste of money to replace the cover as you'll need a new arm soon enough.
PUGPAUL
PostPosted: Wed Dec 07, 2011 1:56 pm Up
not coming up on my browser for 206 HDi 1.4. I called my local main dealer who said that the gaiter is not available separately and several other local factors confirmed this too.
PUGPAUL
PostPosted: Wed Dec 07, 2011 1:58 pm Up
many thanx!
PUGPAUL
PostPosted: Mon Jan 23, 2012 12:43 pm Up
EVENTUALLY MANAGED to see the service box diagram and it DOES list a ball joint gaiter [EDWARD], 2 collars, and a protector.
...this time main dealer said: "each of those are only available in packs of 20". They didn't remember telling me that you couldn't buy them separately in the first place! i.e. complete arm only!
...managed to get hold of ONE from this guy: boot/gaiter.
...and got the collars and protector from: protector/collars
