Online Now [638]:
Visitors: 637
Today: 204828
Total: 152831630
Forums › The Car › 206 Problems › Battery draining problem
mikey1991
PostPosted: Wed Feb 29, 2012 7:02 am Up
Hi, my Peugeot 206 from 2002 is having big battery problems!! I checked that the alternator is charging which it is fine, but when I leave it over night it won't start the next morning, I have tried 2 brand new battery's but the same problem, anyone have any idea what's causing it??
PostPosted: Wed Feb 29, 2012 7:11 am Up
Youve got something on that shouldnt be. Do you have an audio amp in your car?
mikey1991
PostPosted: Wed Feb 29, 2012 7:13 am Up
No it's completely standard,
yo
PostPosted: Wed Feb 29, 2012 5:14 pm Up
Some after market radios don't fully turn off when you press the off button and draw enough current to flatten the battery. They do turn off (like a PC) if you hold the off button for 4 or 5 seconds. Had this with a Sony CD/Radio unit on my wife's Alfa 156.
If it's not that then you are into pulling fuses to see which circuit is drawing current when the ignition is off.
After market alarm or failing alarm system?
PostPosted: Wed Feb 29, 2012 5:17 pm Up
Not a good idea with a multiplexed 206 Wink
Ash
PostPosted: Thu Mar 01, 2012 1:37 pm Up
Sure the alt is charging correctly? All the connections secure?
