Online Now [653]:
Visitors: 653
Today: 224041
Total: 150288975
Forums › The Car › 206 Talk › Overspeed Warning
Overspeed Warning
Forum Index › 206 Talk
PostPosted: Tue Aug 14, 2012 12:14 pm Up
I found this setting in my BSI using pp2000, basically its a speed warning system, if you go over a set speed limit it lets you know, i cant get it to work though! It come up on my MFD, but i cant set a speed limit. Does this need to be set in the BSI, or is it related to cruise control?
PostPosted: Tue Aug 14, 2012 2:37 pm Up
If that don't work you can use the other speed warming system that all cars have as standard-
the speedometer. Wink
Barking
PostPosted: Tue Aug 14, 2012 3:30 pm Up
The only thing that controls the speed of the car without driver input is the rev limiter.
Without cruise control you can't set a speed limit that the car can adhere to on a 206.
Saying that though, my VW has, as standard, a speed limiter/governor that isn't connected to the cruise control (accessed via the onboard computer) for winter driving etc. The 206 isn't that technical though lol
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Tue Aug 14, 2012 3:42 pm Up
You need the cruise control stalk fitted & also the cruise control working to use the overspeed warning on the 206.
Mattie-RS
PostPosted: Tue Aug 14, 2012 4:25 pm Up
My Clio can either be switched to C/C or S/L, stupid 206's Razz
PostPosted: Wed Aug 15, 2012 12:04 pm Up
From what I know it is standard issue for all 206 sold in Saudi Arabia due to legislation there.
If they all have cruise-ctrl I don't know.
