Latest: eltel666
Overall: 17146
Online Now [104]:
Visitors: 103
Today: 4950
Total: 116227689
Forums › The Car › 206 Problems › alarm and auto wiper issue
gtijames22
PostPosted: Wed Feb 20, 2013 11:08 am Up
hi, i do not think my standard alarm is operational, i checked the fuses and the button inside but still nothing. is this a take it to peugeot problem or has anyone else had this problem.
and for the auto wipers, the auto lights come on fine but the auto wipers dont, is there a seperate on/off fuction or do i need a new sensor.
any help would be appreciated, thanks.
PostPosted: Wed Feb 20, 2013 11:15 am Up
You need to move the wiper stalk to the AUTO position every time you want the wipers to be in automatic mode.
Once the ignition is switched OFF it cancels the auto wipers.
As for the alarm, press the lock button on the remote fob ONCE only, this will set the deadlocks & arm the alarm system.
Pressing the lock button a 2nd time within 5 seconds actually cancels the alarm & also the deadlocks.
It sounds to me you are running an earlier BSI software package.
gtijames22
PostPosted: Wed Feb 20, 2013 1:57 pm Up
thx for the wiper info but the 206 is an 05 plate 180 so its the latest software, i do the one press method and still no alarm armed, tried shaking the car etc, wonder what it is :/
GTI 180 JIM
PostPosted: Wed Feb 20, 2013 2:28 pm Up
Do you understand what the button inside does? Have you tried locking the car whilst your sat inside. Mine can take upto a minute to arm itself.
gtijames22
PostPosted: Wed Feb 20, 2013 3:37 pm Up
yup even waited over a minute inside thats why im sure its gubbed, does the button inside have a light to say its activated, if it does then i know mines doesnt work.
GTI 180 JIM
gtijames22
PostPosted: Wed Feb 20, 2013 4:12 pm Up
right done another check, if press the fob twice and sit inside, i open the door from the inside then close it then the alarm sounds, but try everything with the fob clicked once and no alarm, what am i doing wrong?
GTI 180 JIM
PostPosted: Wed Feb 20, 2013 4:32 pm Up
If you hold the button behind the handbrake, its turns off the alarm. With the ignition off the alarm light on the centre dash should flash.
you shouldnt be able to open the doors from the inside, if you lock the car with the fob once.
gtijames22
PostPosted: Wed Feb 20, 2013 4:54 pm Up
yeah ive done that so thats me more or less locked in the car, i am waving my arms like a madman, (fob pressed once) and no internal alarm sounds, maybe my sensors are nacked
GTI 180 JIM
PostPosted: Wed Feb 20, 2013 5:01 pm Up
Thats what it sounds like TBH.
Also, see this topic
www.206info.co.uk/Foru...tml#575494
gtijames22
PostPosted: Wed Feb 20, 2013 5:18 pm Up
thanks mate, gna have a look 2moro and will let u know what the fault was,.
GTI 180 JIM
PostPosted: Wed Feb 20, 2013 6:02 pm Up
Laughing
Unless it's been back to a Peugeot main dealer & had the BSI software updated since its been registered it WONT be running the latest software Wink
My 03 plate car is running 2007 BSI software.
gtijames22
PostPosted: Wed Feb 20, 2013 8:15 pm Up
fair point actually, im gna have a play with it again 2moro Wink
GTI 180 JIM
gtijames22
PostPosted: Fri Mar 01, 2013 9:16 pm Up
can anyone send me a link to getting new ultrasonic sensors please, tried fleabay and google etc, find out that the previous owner lodged blu tac in one of them and no chance of getting it all out and does anyone know how much the software update would set me back?
thanks
GTI 180 JIM
PostPosted: Sat Mar 02, 2013 7:23 am Up
thanks
A new pair of ultrasonic sensors is only £28.10 including the VAT from any Peugeot main dealer.
There simple plug & play BUT be warned the brown plug under the dash is a swine to unplug, the cable runs up the drivers A pillar behind the trim & across the roof behind the headlining panel to the passenger side for the 2nd sensor.
While your at the dealer buying the ultrasonic's you can ask how much they charge for a software update.
gtijames22
PostPosted: Sat Mar 02, 2013 11:31 am Up
thanks mate, yeah seen that switch and checked it was in properly, thanks for the help mate, appreciated Smile
GTI 180 JIM
