Online Now [876]:
Visitors: 875
Today: 161673
Total: 152558188
Forums › The Car › 206 Problems › Dash lights when turning the car on
Tolkienfan001
PostPosted: Wed May 15, 2013 3:44 pm Up
Trade Rating: +13
Can someone please post a pic of what lights are on on the instrument cluster when starting the car (multiplex).
I am getting a single beep with no warning lights and am running out of ideas as to what it could be. I am wondering if I may have a blown bulb and a warning light should be showing with the beep....
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Wed May 15, 2013 4:13 pm Up
If its beeping, it usually shows on the MFD. would either be brakes or airbags I'd imagine.
Tolkienfan001
PostPosted: Wed May 15, 2013 4:16 pm Up
Trade Rating: +13
No mfd message and no warning lights. Oil and brake fluid fine. I must have a dodgy sensor or something but what I do not know.
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 3:52 am Up
2003 1.4 8v
This is when I first turn on the ignition
and this is a couple of seconds later just before turning the key to start the engine
The beep isn't something daft like service due or the door is open is it?
Big_Rich180
PostPosted: Thu May 16, 2013 4:00 am Up
It probably isnt this but I used to get a single beep on start up when my ABS was shagged.
Tolkienfan001
PostPosted: Thu May 16, 2013 4:15 am Up
Trade Rating: +13
Ok this is interesting. Macca do you have ABS? When I turn the ignition on my abs light comes on then goes off with the other lights.
The beep happens only under braking just before I come to a stop. Only when the car is at running temp ( maybe when the brakes are hot?) I have new discs and pads on the front.
If this is an ABS issue what am I looking for? This is my first car with ABS.
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 5:07 am Up
No ABS on mine.
I take it planet isn't chucking anything up.
Have you cleaned the ABS rings and sensors? could be a bit of crap on one of the rings that is only picked up at low speed.
Not sure if any 206 comes with brake wear sensors. If yours has them, it is possible that they could be faulty at higher temps.
Also do you leave your foot firmly on the brake pedal until you come to a complete stop, or ease off the brake as you are coming to a stop?
Tolkienfan001
PostPosted: Thu May 16, 2013 5:42 am Up
Trade Rating: +13
I don't have pp2000. Ido ease off as I come to a stop...
2005 1.4 16v Sport
PostPosted: Thu May 16, 2013 9:12 am Up
No it doesn't.
broadblaster
PostPosted: Thu May 16, 2013 3:03 pm Up
does the car have a low brake fluid warning ???
if it does this could come on under brakeing as the level will drop as you press the pedel.
on a back road playing
Tolkienfan001
PostPosted: Thu May 16, 2013 3:10 pm Up
Trade Rating: +13
It's on max...
2005 1.4 16v Sport
broadblaster
PostPosted: Thu May 16, 2013 3:13 pm Up
Tolkienfan001 wrote:
It's on max...
ok mate it was just a random thought Smile
