Latest: ArtistKS
Overall: 17145
Online Now [314]:
Visitors: 313
Today: 950
Total: 115901265
Forums › The Car › 206 Problems › Millage not showing
Millage not showing
yorkshirelad
PostPosted: Tue Mar 29, 2016 1:20 pm Up
My millage is not showing on my dash and my fuel and oil needle is reading wrong any help would be great.
2000 1.9d lx
PostPosted: Tue Mar 29, 2016 1:29 pm Up
Mileage could simply be the bulb has blown that backlights the lcd display.
Start the engine then shine a torch at the lcd display & see if there is a reading showing.
Dekzion
PostPosted: Tue Apr 05, 2016 6:36 am Up
Thanks for that info Mr BSI that was one of my intended questions answered too!
Hmm,, next trick,, how the heck to get in to replace the bulb!
mtempsch
PostPosted: Tue Apr 05, 2016 8:37 am Up
Grab the top cover at the edge by the windshiekd. Pull towards you to unclip it, Loosen torx screw (T20 IIRC) , tilt cluster towards you, undo the fasteners on the connectors at the back and then unplug.
Don't remember if the idometer bulb is available from the outside (the rest of the bulbs are, so it probably is) or if you need to undo the back of the cluster.
Here's a video.
Silvermetallic 2004 206 RC
Dekzion
PostPosted: Fri Apr 08, 2016 2:10 am Up
Job done! thanks mtempsch and MrBSI, it took under 5 minutes and I have mileage again!
