Posted: Thu Aug 05, 2010 4:37 pm |
Ok ... total noob here..
First time buying wiper blades, few questions.
I have a 52 plate 206.
1) What are aero blades? Are they much better?
2) Are aero blades easy to fit?
3) Prices? Recommendations?
4) Will these fit:
cgi.ebay.co.uk/PEUGUOT...497wt_1026
5) What size am I looking at for my 206, front and rear?
Sorry for so many questions - this is my first time buying ... it was the 'tesco' thread that made me aware of aero wipers...
Posted: Fri Aug 06, 2010 1:37 am |
Aero are nice! Dont buy them cheap ones, Buy cheap buy twice.
Bosch do really good ones example here
They are the same to fit as normal wipers. Not sure what your sizes are, but my car is 02 and the wipers are 22/22 on the front. The rear wiper is the same on every car.
Check out www.wiperblades.co.uk and go through the car checks and it will present you with what you need at the end.
Posted: Fri Aug 06, 2010 1:41 am |
Cheers 206 - they're a bit more than I thought they'd be when I saw all the cheap prices on ebay haha
I'll wait until my car's back from the body shop and have a look then.
Cheers again
Them ones on wiperblades.co.uk are only 6.20 each... that sounds a good price? They're also recommended by Auto Express which I read regularly so I might get them ...
Posted: Fri Aug 06, 2010 1:56 am |
aero blades from tesco are about £6 each and work brilliantly use search bar and search tesco wiper blades and have a look.
Posted: Fri Aug 06, 2010 2:25 am |
Oh, cheers Dan - will have a look now.
Posted: Fri Aug 06, 2010 2:26 am |
no probs!
Posted: Fri Aug 06, 2010 2:50 am |
may get meself a set of them. . .
Posted: Fri Aug 06, 2010 1:00 pm |
I just ordered a set - once my car gets back from the body shop, I'll put them on and let you know how I get on.
Posted: Fri Aug 06, 2010 1:45 pm |
Aeroblades don't wipe any better than normal window wipers, they just look better.
Also with aeroblades you need a inch shorter, so its 21/21
Posted: Fri Aug 06, 2010 2:58 pm |
Dam. Wiperblades.co.uk told me I need two 22" so that's what I bought.
I'll see what happens and return them if they don't fit, thanks for the heads up Lee
Posted: Sat Feb 01, 2014 8:10 am |
Ordered a set of 22" aero wipers.
Ad even stated "peugeot 206".
Wiper on o/s hits the window trim on the side nearly bending the wiper?
Is it the wiper being too big? The seller being a retard and not giving right size (states 22" on the box), or aero wipers need to come in smaller size to fit?
Posted: Sat Feb 01, 2014 8:18 am |
I have the same problem with the o/s hitting the window trim
What I did to cure it was slightly file down the end of the wiper blade.
| Nissan Pulsar C13 Owners Club
Mod List:
Lowered 30mm
HEL Braided Brake Lines
EMP Backbox Delete
Full Custom Audio Build
Full LED Light Conversion
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar | |
Posted: Sat Feb 01, 2014 8:30 am |
Although 22" is correct for OEM, it has been found that the 21" aero fits perfectly. Some compatibility lists will state that 22" is needed which makes it really confusing.
Posted: Sat Feb 01, 2014 9:10 am |
Thanks guys. May contact the seller to see if he will swap.
Is it suggested 21 for both sides? Or just o/s
Posted: Sat Feb 01, 2014 9:21 am |
I got a 21s on both sides. Not had a problem with them
