Latest: tc.206
Overall: 17147
Online Now [411]:
Visitors: 409
Members: 1
Today: 23655
Total: 116478654
Forums › The Car › 206 Problems › electrical problems on 1.6 16v
firefighter1
PostPosted: Wed Jan 26, 2011 5:56 pm Up
Help please, posted in error on general talk yesterday
Hi there, new on here and have problems with a x reg 206 roland garros, non starter, no electric windows and centre consol not working?
managed to start car by using power probe to supply live feed direct to fuel tank sender /pump unit and car runs fine, but soon as power removed car dies, replaced multi function relay (brown one under ecu on n/s), checked all fuses but none blown
any ideas would be gradly received,
Abzynthe
PostPosted: Wed Jan 26, 2011 5:58 pm Up
East Area Rep - Abzynthe
I just guessing here, but flat battery and alternator gone?
wull
PostPosted: Wed Jan 26, 2011 6:02 pm Up
have you checked the voltage at the battery?
2000 gti
firefighter1
PostPosted: Wed Jan 26, 2011 6:17 pm Up
oops forgot to mention, fitted new battery and alternator charging 13.8- 14ish volts so no problem there,
peugeot fan, have a few and working on a few lol
wull
PostPosted: Wed Jan 26, 2011 6:23 pm Up
what about ignition lights?do they come on at all when you turn the ignition on?
2000 gti
firefighter1
PostPosted: Fri Jan 28, 2011 6:05 pm Up
Yes all ignition lights working ok when key turns on etc
XSIcheeseman
PostPosted: Fri Jan 28, 2011 6:39 pm Up
then its probs a major earthin problem somewhere or there is a wire broken somewhere . what have you touched or done before it happened?
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
firefighter1
PostPosted: Sat Jan 29, 2011 12:30 pm Up
car completely std , and nothing touched.
car started to cut out sometimes, but nothing found and always seemed to then just restart, but now been dead for couple of weeks, i can do basic stuff and checked visually for rust etc round earths i could see,
suspected a bad earth or broken connection some where ?
any one got any ideas where all earth connections are and is there poss any common places to look for bad wireing etc
a friends mech said suspect area is wiring loom that goes under engine ?
suspect ill end up probably taking to auto electrician ?
firefighter1
PostPosted: Tue Feb 15, 2011 6:40 pm Up
well just to keep you updated , after changing mult function relay under ECU car didnt run, after more checking and asking advice from a friend at local peu garage, traced fault to fuel inertia cut off switch , some how wiring block connector was loose, all runs fine now , electric windows all work fine , air con and blower now all work.
still no fuel guage and still no genuine radio and also top centre console not working ?
trying a set of clocks from my other peu 206, will try non std cd player, unless any body else has any further suggestions? will probably have to get second hand centre display as mine in other car much smaller?
