Forums › Tuning, Modification & Legal › Project Cars › ushers track project fully stripped and trimmed |
Posted: Wed Apr 23, 2014 1:05 am |
Ever thought there's a reason for that radiator cowling to be there?
Posted: Wed Apr 23, 2014 2:40 pm |
Economy? It's still got top and botttom mounts
Posted: Wed Apr 23, 2014 4:00 pm |
It's there to make sure the air goes through the radiator rather than round the sides of it.
Posted: Wed Apr 23, 2014 4:44 pm |
Surely you can make something like white noise did in his project thread
Posted: Mon May 26, 2014 12:35 pm |
ittle update had a hr or so on the car, got the key barrel out and wired in the switch pannel i got for it, relativly straight forward think the imobilizer is not working as the key was outside the car without the sensor connected ??? wonder how big the range is on the sensor also identified side light wires but struggling to find the main dipped and indecators so might end up tracing backwards
Posted: Mon May 26, 2014 5:08 pm |
Why is it all rusty?
Posted: Mon May 26, 2014 5:38 pm |
I left it outside when I was removing all the sound proofing. Joys of working outside
Posted: Sun Jun 08, 2014 9:47 am |
little progress but it all helps
got the battery set up in the boot just needs neatening when i do all the wires
Posted: Sun Jun 08, 2014 10:18 am |
I would have wired that straight through to the starter and alternator. All that wiring needs supporting too.
Posted: Sun Jun 08, 2014 11:42 am |
Yeah needs finishing as yet just main work doneevery thing will be sorted once all wiring has been done and all switched then I'll startto put it all vback in and clip all the wires down with p clips or similar. Might leave the fuse box in place of the glove box and have all switches in the centre console where the hu used to be and heater control
Posted: Sun Jun 08, 2014 4:08 pm |
Nice !
I'm planning to put my battery in the back as well.
Is there a guide how to properly do it on a Gti 180 ?
Posted: Mon Jun 09, 2014 12:02 am |
basically what you see in the pics, it will be the same for the 180
i used welding cable 5mtr then put audio wiring crimp terminal on the end and bolted the + ive together and moved the earth to the chassis earth and re earthed the battery in the boot, realy simple
Posted: Fri Jun 20, 2014 10:25 am |
Trade Rating: +46
still comming along nicelly usher.
Posted: Fri Jun 20, 2014 4:54 pm |
thanks next is to put the lights and wipers on switched and put it back together neatly
after i get discs and pads with seats fitted it will be caged, hopefully this year
Posted: Mon Jul 14, 2014 2:21 pm |
tiny update
bsi is now in the bin so more wires to be removed, lights and wipers to wire still
also took off bumpers and jet washed behind them and cleaned up the little parts involved, fog to be used as brake cooling ducts so cut away at the glass, noticed one tyre had gone flat which caused a nice big deep crack so the wheels will be sold on and new either td's pro race or 205 speedlines going for 15"
