Online Now [100]:
Visitors: 99
Today: 7557
Total: 143076073
Forums › The Car › 206 Problems › ICV Help from anyone with experience!
MrrNoName
PostPosted: Mon Apr 04, 2011 9:15 am Up
Hi, ive taken my idle control valve off to clean it as i think its causing me a rev problem.
anyway, ive got it out and am cleaning it but the little piston wont move, its locked in a position, should I be able to move it in and out manually?
there is a metal sleeve over the piston thing the I can push down but it springs back out to cover the piston thing up again as soon as I let go,
should it be locked in this position or freely work in and out-able if, sorry thats the only way i know how to describe it haha
thanks for any help in advance, MrrNoName
PostPosted: Mon Apr 04, 2011 9:16 am Up
Yes it should move, given it a good spray with carb cleaner?
MrrNoName
PostPosted: Mon Apr 04, 2011 10:01 am Up
yeh sprayed it to death lol, i can move it in and out now, its extremely stiff though, i was wondering if it should be like this to move by hand or if it should move freely and easily?
if it should not be this stiff thats probably the problem lol!
PostPosted: Mon Apr 04, 2011 10:08 am Up
It should be stiff?
MrrNoName
PostPosted: Tue Apr 05, 2011 1:38 am Up
should it? lol thats what im trying to find out
mattievrs
PostPosted: Tue Apr 05, 2011 2:39 am Up
inside the black plastic is basically a motor. The shaft length is determined by the motor which spins the shaft in and out dependant on revs needed. So yes it will be stiff.
NO LONGER ACTIVE ON THE FORUM
MrrNoName
PostPosted: Tue Apr 05, 2011 3:59 am Up
ahh ok, thanks Smile
PostPosted: Tue Apr 05, 2011 5:13 am Up
So other that a little bit of free play it won't move significantly.
