Latest: S2cgm
Overall: 17178
Online Now [51]:
Visitors: 49
Bots: 2
Today: 1526
Total: 136323539
Forums › The Car › 206 Problems › Removing the struts
Removing the struts
Go to page Previous  1, 2
Didz
PostPosted: Tue Apr 05, 2011 12:17 pm Up
Remove the hub from the ball joint as said. My top tip is to undo the middle bottom arm bolt too. This gives you the movement needed especially when putting the pin back in the hub. Then when the hub is back on the arm push it all in and wiggle a punch or similar to align the middle hole up to push the bolt back through.
should make removing/fitting the shocks alot easier. Also you can buy a bar like a fork. Great for
Life's for living....
PostPosted: Tue Apr 05, 2011 1:34 pm Up
Great for ruining the ball joint rubber.
Didz
PostPosted: Tue Apr 05, 2011 3:00 pm Up
Not if used right. I've never split one I shouldn't of yet. The rubber pulls down easily. Just be carful to place the fork above it. Use a screwdriver to pry it down if you have too.
PostPosted: Tue Apr 05, 2011 3:32 pm Up
Good ideas Smile thanks will have another bash on Friday when uni is over
Edward I take it that's with the top mount bolts still attached? Couldn't think how it could pressure it up otherwise
Didz
PostPosted: Tue Apr 05, 2011 4:28 pm Up
yeah, undo them last matey
PostPosted: Wed Apr 06, 2011 2:42 am Up
Cheers, undid them first that may have not helped at all Embarassed
Page 2 of 2
