Toggle Content Quick Search
Toggle Content Donations
We need your help! Every little counts!
So far we have raised £5.00 this month using this button!
Latest: notrix
New Yesterday: 7
Overall: 8794
Online Now [20]:
Visitors: 9
Bots: 2
Members: 9
Today: 19381
Total: 30990256
Forums › The Car › 206 Problems › Removing the struts
Removing the struts
Go to page Previous  1, 2
Reply to topic Printer Friendly Page  View Previous Topic View Next Topic
Didz
PostPosted: Tue Apr 05, 2011 6:17 pm Up
Remove the hub from the ball joint as said. My top tip is to undo the middle bottom arm bolt too. This gives you the movement needed especially when putting the pin back in the hub. Then when the hub is back on the arm push it all in and wiggle a punch or similar to align the middle hole up to push the bolt back through.
should make removing/fitting the shocks alot easier. Also you can buy a bar like a fork. Great for
Life's for living....
PostPosted: Tue Apr 05, 2011 7:34 pm Up
Great for ruining the ball joint rubber.
2001 GTi 138, Bilstein B8 Sprint dampers, H&R springs, 21mm Peugeot Sport torsion bars, 22mm rear ARB, Peugeot Sport GP A wishbones, 283mm discs, Goodridge hoses, Maniflow 4-2-1 304 grade manifold and 2.5" system, 200 cell cat, Richard Longman head, 42mm Jenvey Throttle bodies, Piper Ultimate Road cams, Piper vernier pulleys, ACT/Longman/Jenvey carbon fibre airbox, Omex 600 ECU. Vibra Technics engine mounts. Samco coolant hoses, DP Engineering thermostat housing. Very shiny. 2006 VW Jetta 2.0 TDi Sport for everyday use. 2008 207CC 1.6 GT.
Didz
PostPosted: Tue Apr 05, 2011 9:00 pm Up
Not if used right. I've never split one I shouldn't of yet. The rubber pulls down easily. Just be carful to place the fork above it. Use a screwdriver to pry it down if you have too.
PostPosted: Tue Apr 05, 2011 9:32 pm Up
Trade Rating: +86
Good ideas Smile thanks will have another bash on Friday when uni is over
Edward I take it that's with the top mount bolts still attached? Couldn't think how it could pressure it up otherwise
Arrow XSI WIP
Arrow GTI 137/138/180 parts for sale
Didz
PostPosted: Tue Apr 05, 2011 10:28 pm Up
yeah, undo them last matey
PostPosted: Wed Apr 06, 2011 8:42 am Up
Trade Rating: +86
Cheers, undid them first that may have not helped at all Embarassed
Arrow XSI WIP
Reply to topic Printer Friendly Page  View Previous Topic View Next Topic All times are GMT
Page 2 of 2
