Posted: Sat Oct 09, 2010 8:16 am |
Off CS
Posted: Sun Oct 10, 2010 12:38 pm |
Posted: Sun Oct 10, 2010 1:09 pm |
I've sorted my old one now. Ditched all the servos and anything that wasn't essential and it's now fairly light.
| ICE goes in drinks. NOT in cars. | |
Posted: Tue Oct 12, 2010 6:17 pm |
Posted: Tue Oct 12, 2010 6:18 pm |
Posted: Wed Oct 13, 2010 1:26 am |
Are you going to put fillets between the cage and A and B posts??? I love fillets...
Posted: Wed Oct 13, 2010 5:52 am |
Yes I am. I love fillets too. Just ordered the hydraulic handbrake, line lock and bias valve.
Posted: Wed Oct 13, 2010 5:57 am |
Why does a track car need a hydraulic handbrake?
Posted: Wed Oct 13, 2010 6:19 am |
nice bit of weldng mate, looking good!!!;)
Posted: Wed Oct 13, 2010 7:27 am |
Edward wrote: |
Why does a track car need a hydraulic handbrake? |
So in the future if i decide funds allow me to start stage rallying again it's ready set up for it. I know what you mean. It's totally not needed on a track car but I have in the past needed the handbrake to correct a bit of understeer and the gti cable hand brakes are so s**t it was a struggle. With the hydraulic one it makes it so much easier and controlable.
Posted: Wed Oct 13, 2010 1:49 pm |
And in other news, check this haul
Posted: Wed Oct 13, 2010 2:46 pm |
oooo yummy, what cage is that?
Custom Cages?
Sam.
Posted: Wed Oct 13, 2010 2:53 pm |
Have you made allowances for removing the rear beam if needed. I had to bolt thru my rear cage mount into the rear mounts of the rear beam..
Posted: Wed Oct 13, 2010 3:55 pm |
Yes mate. rear beam is still accessable.
Posted: Wed Oct 13, 2010 5:27 pm |
