Latest: evert
Overall: 17112
Online Now [101]:
Visitors: 101
Today: 10884
Total: 93744236
Forums › Tuning, Modification & Legal › Project Cars › Tiffany - 138 Race Car Project
Ape
PostPosted: Mon Oct 10, 2011 4:21 am Up
I quite like that!
PostPosted: Tue Oct 18, 2011 11:16 am Up
Thanks mate
It will look nicer when i make a splitter that covers under the engine to bring the airflow to the under floor (may help may not)
Then once from the floor to a diffuser at the back that covers the rear axle and boot floor/spare wheel whole
Mattie-RS
PostPosted: Tue Oct 18, 2011 4:54 pm Up
Addaz wrote:
Thanks mate
It should do, well Renault Sport thinks so,
My 197 has Front splitter and diffuser, and Rear diffuser
PostPosted: Mon May 21, 2012 3:36 pm Up
Almost forgot about this Laughing
Ermm yeh, couple of bits have changed
- New bottom arms, track rod ends, drop links, ARB bushes and top mount bearings
- The loom is completely stripped
- The rear tailgate has 'finally' been cut out
- The N/S headlight is now an induction point Laughing
And yeh she will be out hopefully on the 25th june at snett
PostPosted: Mon Jul 30, 2012 11:39 am Up
I like pink?
And one with my third love of my life <3
PostPosted: Mon Jul 30, 2012 12:14 pm Up
You removed the air conditioning? Save about 10kg.
PostPosted: Mon Jul 30, 2012 1:17 pm Up
Addaz wrote:
I like pink?
i have to say those pink looks hot Razz
PostPosted: Tue Jul 31, 2012 3:05 pm Up
Yes i have edward, did that pretty much first
Shorter belt adding the removal off the pump too
Literally anything that doesnt need to be there isnt
PostPosted: Tue Jul 31, 2012 3:24 pm Up
More to the point, when is she going to be finished?!
PostPosted: Tue Jul 31, 2012 3:27 pm Up
When the scooby stops f*****g breaking and lucy is done......
So never in other words Laughing
PostPosted: Tue Jul 31, 2012 3:29 pm Up
Was going to say, I don't think you have any hope if the other cars gets put first haha
Shame, by the time you sort it out you will have no chance of catching me when the paxo is finished Wink
PostPosted: Tue Jul 31, 2012 3:31 pm Up
That before or after ive considered a turbo conversion on the track car? Wink
V6 turbo? Shocked
PostPosted: Tue Jul 31, 2012 3:33 pm Up
Depends what time frame you are talking about, I would probably have scrapped it by then Laughing
V6 turbo would be mad.. 300bhp easy?
Need to finish the current conversion first though Wink
PostPosted: Tue Jul 31, 2012 3:36 pm Up
I have a bit of an engine building bug, and i would look for more 400 to 500, but it would be a first would it not? Wink
Pretty simple when you think about it, strip it down, new rings, new seals, stronger rods if available if not just a decomp plate and run it on a standalone ECU.
Less wiring and a lot more fun
Nic_206
PostPosted: Wed Aug 01, 2012 4:18 pm Up
some one told me you the standard v6 internals can with stand upto 300bhp and there was a bloke that did a remote turbo to his v6 406 and it sounded epic unsure of the power it kicked out though if you was putting say 450 bhp in im guessing it would be 4wd mate?
Ford focus st3 daily driver
Team: Red 20v6
Page 6 of 8
