Posted: Fri Oct 28, 2016 10:10 pm |
Hello all,
I'm new to the peugeot scene, had a variant of different cars in the past, from turbos to v8's but wanted a capable and reliable track car, was originally looking at Clio 182's but fancied being a bit different then come across the Gti 180's.
Spent a few months and a few wasted views looking for a half decent one when I came across this decent Aegean Blue 180. Seemed good enough and was close enough so I brought it, it needed some love but overall was ok.
So plan to start with was to get it back up to a decent standard, changed rear lights back to standard, fix the rear boot lock, etc
Posted: Fri Oct 28, 2016 11:26 pm |
Here is a few snaps of when I collected the car / advert photos
Posted: Sat Oct 29, 2016 7:45 am |
it's a very nice car,this color is charming by all means
Posted: Sat Oct 29, 2016 7:26 pm |
You will probably have most things or will be removing some to make it more track friendly but if you need any spares let me know, got a aegean blue 180 im breaking.
Looks lovely though, got some ph2 rear lights if your interested lol.....
| 2004 GTI 180 - SOLD, 2000 GTI - SOLD, 2002 SW D TURBO - CURRENT | |
Posted: Sun Oct 30, 2016 9:01 am |
Looks mint fella (especially after your detailing and SP arches), but what happened to your GTi 138?
Posted: Sun Oct 30, 2016 2:08 pm |
Looks a cracker mate, you definitely picked the right colour but then i'm a bit bias
Posted: Sun Oct 30, 2016 9:07 pm |
Thanks everyone, done quite a bit to it over the last 3 months since I brought it,
changed the rear lights back to standard,
removed all interior,
added 2 bucket seats,
Removed door cards and made replacement blanks
Neaten up all wiring
6point fia approved harnesses,
safety devices cage ( which is actually getting fitted this week)
rear anti roll bar,
gas coilovers,
15" track wheels and ad08r tyres,
yellow stuff pads all round,
5.1 brake fluid and drained out all old fluid, ducts to cool front brakes as found they fade under constant breaking while on track
Looking at fitting a 19 row oil cooler when back from getting cage fitted
Posted: Sun Oct 30, 2016 9:08 pm |
Sim wrote: |
Looks mint fella (especially after your detailing and SP arches), but what happened to your GTi 138? |
The 138 Gti I used for one track day, decided I loved it but needed a 180, so sold on eBay and replaced with the 180 when a nice one came up
Posted: Mon Oct 31, 2016 6:23 am |
There's my cage all ready to go, hopefully that's in by the end of the week as at Bedford autodrome on Saturday!
Posted: Mon Oct 31, 2016 6:56 am |
Wind deflectors on a track car? Wheel arch extensions need to come off too.
Posted: Mon Oct 31, 2016 7:30 am |
Looks very tidy!! But is true what Edward said as well as cooling efficiency through that SP grille as per my concern here: www.206info.co.uk/Foru...tml#653095
But probably you want to keep balance between looks and tracks
Will definitely be interested in your lap times and how they improve in months to come!
Posted: Mon Oct 31, 2016 8:01 am |
Sim wrote: |
Will definitely be interested in your lap times and how they improve in months to come! | That was Gaz
And I am busy reading up on it and drawing more ideas.
I start to understand what Gazza was saying and I do agree with him. Hence I am going to make a custom shroud likely which covers most of the bay (even more than the current one). Still thinking and learning on the best way to do it.
Also want to make a duct from the front to the inlet; to provide additional cooling directly on the inlet itself.
| Current project: Ciri
Silver 206cc - 2.0 - 2001 | |
Posted: Mon Oct 31, 2016 8:29 am |
Has it got one of those clamp on rear ARBs on it?
Posted: Mon Oct 31, 2016 10:44 am |
The deflectors came on the car but is nice to have the windows cracked open while on track, as I believe your not supposed to have windows open while on track.
At present it's a hobby track car and I've only done 2 track days in it, I am trying new things as I go, my most recent add was the brake ducts as first time I used it I noticed the fade as they got up in temps.
Yeah it had a white line clamp on rear arb .
Posted: Mon Oct 31, 2016 12:05 pm |
Get plastic windows with the slides you can open. Also takes weight down, as glass is heavy. Poly carbs are about 70 quid I believe.
