Latest: eniniex
Overall: 17113
Online Now [29]:
Visitors: 28
Today: 10682
Total: 93813611
Forums › The Car › 206 Problems › Abs Pump how to replace? HELP!! URGENT
Atitudejim
PostPosted: Sat Jul 16, 2011 4:00 pm Up
Is replacing the ABS pump on a 206 a easy job? straight swap?
any bleeding needed, or could be any electronic issues after fitting it?
i have just put up a deposit for a 206 that am picking it up next wednesday.
when i was inspecting it i noticed there was quite empty space next to the air filter box and noticed 2 disconnected plugs, i was curious... and found out the abs pump is missing....
and according to the seller (a dealer) it has a fresh mot.
any ideas? the car is cheap... £925 for a 2002 206 2.0hdi ..... so if its just getting a pump and fitting... and the job is easy im up for it... as the pump in my local scrappy is around 20 quid...
any ideas? thanks in advance
2002 Peugeot 206 2.0 Hdi 90
2002 Citroen C5 Hdi 110 Estate with some Poke Wink
PostPosted: Sat Jul 16, 2011 4:04 pm Up
Might not have ABS as standard
PostPosted: Sat Jul 16, 2011 4:09 pm Up
would be a nighmare to retrofit ABS
Atitudejim
PostPosted: Sat Jul 16, 2011 4:12 pm Up
i thought they all came with abs.... maybe this one hasn´t
the model is 2002 PEUGEOT 206 2.0 HDi 90 LX SR 3dr....
is there any way to find that its the non abs or it was fiddled about?
thanks
PostPosted: Sat Jul 16, 2011 4:14 pm Up
LX was a poverty spec, doubt it will have come with ABS
If you get the chassis number, I'll look it up for you
dumdum0910
PostPosted: Sat Jul 16, 2011 4:18 pm Up
when i was looking at 206 before i got mine i looked at a couple that never had abs
PostPosted: Sat Jul 16, 2011 4:20 pm Up
mine don't have abs.
2.0HDi d-turbo
Atitudejim
PostPosted: Sat Jul 16, 2011 4:24 pm Up
thanks for the reply's i was getting worried about it...
thanks again Smile
deanparkr
PostPosted: Sun Jul 17, 2011 1:36 am Up
It seems strange to me that 206 doesnt have ABS in some configs - I thought it would of been a standard thing!
2002 1.4LX
PostPosted: Sun Jul 17, 2011 1:39 am Up
There would be more than just a couple of plugs disconnected if the ABS unit had been removed. There would be all the plumbing to the brakes that would be sat doing nothing.
meady
PostPosted: Sun Jul 17, 2011 1:57 am Up
Trade Rating: +45
I was guna say surely if the abs pump had just been removed then the brakes wouldnt work
TEAM - I HATE FACEBOOK Smile
