Online Now [520]:
Visitors: 519
Today: 160018
Total: 154361422
Forums › The Car › 206 Problems › Driver door open audible "click" noise
karimali831
PostPosted: Wed Jul 20, 2011 7:14 am Up
Hi folks, I'm curious to know if this happens with anyone else... the moment you open the door and it holds it makes an audible annoying "click" sound and again when you push forward to the next hold and back again etc. Other doors are fine...
So I had a look and it seems this is loose...
any ideas??
206 GTI 180
PostPosted: Wed Jul 20, 2011 7:15 am Up
You need a new check strap.
They are interchangeable.
meady
PostPosted: Wed Jul 20, 2011 7:35 am Up
Trade Rating: +45
You can tighten thm bk up, seems to do the trick aswell
TEAM - I HATE FACEBOOK Smile
karimali831
PostPosted: Wed Jul 20, 2011 7:52 am Up
can you show how please? I'd appreciate it a lot Smile
206 GTI 180
xspongerx
PostPosted: Wed Jul 20, 2011 7:55 am Up
you need to clean your inner door Razz
meady
PostPosted: Wed Jul 20, 2011 7:59 am Up
Trade Rating: +45
Basically on the right of you pick, where the check strap goes in the door there is 2 10mm bolts (i think there 10mm anyway) u just need to tighten thm up basically and it will stop it. Smile
karimali831
noo the car is in rust in, rust out it's not worth it..
206 GTI 180
karimali831
PostPosted: Wed Jul 20, 2011 8:46 am Up
Where LOL? I only find one bolt on left and surely it can't be that... thanks.
206 GTI 180
PostPosted: Wed Jul 20, 2011 8:49 am Up
follow that strap with your hand towards the door. You will feel them then.
PostPosted: Wed Jul 20, 2011 9:03 am Up
You need to remove the door card to tighten them. May as well replace it, they're only £15~
MrrNoName
PostPosted: Wed Jul 20, 2011 9:37 am Up
replace it, if you tighten it up the click comes back in a few days Razz
I did mine last week and it gets rid of this "click"
1. open the door
2. remove the inner mirror cover (be careful to remove the tweeter from its clips behind the cover) it simply pulls off
3. undo the screws around the door interior and the one in the handle (what you pull on to close the door from the inside)
4. remove the handle (inner one)
5. remove the door interior (the clips will break but they are cheap as chips from pug so ensure you get more before hand
6. using a sharp knife cut the rubbery stuff holding the white door seal on
7. ensure something is in the way of the door so when you remove the strap the door cannot fly open and damage with wing
8. Undo the two bolts on the check strap (can be accessed by fully opening the door and looking into the strap, use a socket and ratchet)
9. undo the large torx bolt on the cars main body (VERY VERY STIFF, i had to use a large torx key and apply A LOT of pressure)
10. Remove the check strap from inside the door
11. fit the new one (fitting is reverse of removal)
12. Ensure there are NO broken clip bits inside the door as these will rattle around and be annoying (you can use a hoover to suck them up)
13. replace the door seal (if you cut the rubbery stuff well it simply sticks back on) its really easy
14. put the new clips in and put the door interior back on
15. replace the handle and do the screws up
16. replace the inner mirror cover (refit the tweeter)
Job done, It took me less then 30 mins Smile
PostPosted: Wed Jul 20, 2011 9:39 am Up
need to do mine, and grease it up, squeeky door Twisted Evil
easy to do though with door card off
Lewis
PostPosted: Wed Jul 20, 2011 9:42 am Up
sweet how to MrrNoName, surely hes not gonna have any problems now ha
Tivoli LX 1.1
Black GTI 180
White VXR Burg
eddrj
PostPosted: Wed Jul 20, 2011 10:05 am Up
either tighten up and grease if that dont work there about £21 and easy to change.
Old car 2000/ 206 2.0 hdi.
karimali831
PostPosted: Wed Jul 20, 2011 11:40 am Up
I just had a go at tightening the two bolts and at first it felt it tightening then after it loosens and there is no way of actually making it tighter or looser?! Applies for both bolts... and then tested the door and it is much quiet still a minor click though which is ok Smile
And they do cost a lot..
206 GTI 180
