Latest: Kifi69
Overall: 17183
Online Now [508]:
Visitors: 507
Today: 115172
Total: 144406668
Forums › The Car › 206 Problems › replacing coolant
replacing coolant
PostPosted: Sat Jul 23, 2011 8:49 am Up
ok doing the coolant this morning, found the drain plug.
open it and catch the coolant; surprising there is only about 3-3.5L come out.
(from the manual i think it should be at least 6L?)
anyway. top it up with new coolant, it only take about 3L of coolant Confused
that doesn't sounds right to me Laughing
it there any other plug that i need to open in order to drain all the coolant?
MrZiggerz
PostPosted: Sat Jul 23, 2011 9:16 am Up
Did you follow the How-To on here bud?
PostPosted: Sat Jul 23, 2011 9:20 am Up
Just take the bottom hose off! Laughing
PostPosted: Sat Jul 23, 2011 9:28 am Up
so you are saying the drain plug is not used to drain the coolant ? Confused
or do you mean i have to flush the remaining coolant out with water?
PostPosted: Sat Jul 23, 2011 9:40 am Up
No, im saying that I just pulled the bottom hose off the radiator when I changed mine.
PostPosted: Sat Jul 23, 2011 9:44 am Up
might have to do that now Sad
PostPosted: Sat Jul 23, 2011 10:15 am Up
Think of all the coolant in the engine block. By undoing the drain tap or bottom radiator hose you are just emptying the reservoir and radiator. The coolant in the block doesn't come out unless you flush the system through.
I think there's a core plug in the block possibly behind the flywheel but you'd have to be desperate to take that out!
PostPosted: Sat Jul 23, 2011 10:17 am Up
this make more sense now Very Happy
just need to pick up some anti freezer and flush it through
PostPosted: Sat Jul 23, 2011 4:09 pm Up
I've seen some just take the pipes off the water pump to try and get some of it out
gixxerkev
PostPosted: Sun Jul 24, 2011 2:16 am Up
Take the thermostat off as well to drain the block then flush the system through.
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Sun Jul 24, 2011 8:00 am Up
job done. take me ages to flush all of the old coolant out
