Latest: eniniex
Overall: 17113
Online Now [53]:
Visitors: 52
Today: 6063
Total: 93983256
Forums › The Car › 206 Problems › crank position sensor ?
vitara4x4
PostPosted: Fri Aug 26, 2011 8:39 am Up
Hi All,
i have a 2001 206cc 138bhp
i put the car on a fault finder and it told me i had an intermitten crank position sensor.
i have looked every where and cannot find the sensor
could somebody point me into the right direction please.
also the oil temp sensor has also packed in can someone point me to where that is?
thanks in advance Crying or Very sad
206CC SLAMMED TO THE GROUND
macj
PostPosted: Fri Aug 26, 2011 9:57 am Up
top of the gearbox bell housing where it joins engine held in place with single bolt (10mm spanner)
Oil temp is at rear of crank case at cambelt end
PostPosted: Fri Aug 26, 2011 10:03 am Up
PSA still using a brown 3 pin connector plug with gold contacts Laughing
PostPosted: Fri Aug 26, 2011 2:00 pm Up
The crank sensor is on top of the gearbox but buried under the thermostat housing. You'll need to take the battery and box out to see it.
Looks like this.
See the green coolant temp sensor on the left? Directly below that is the crank sensor.
vitara4x4
PostPosted: Sat Aug 27, 2011 11:44 am Up
thanks guys
found the little critter.
when i changed the clutch a few months back i only unclipped the wires not taken out the sensor.
looks like i damaged it putting the gearbox back on. Embarassed
cheers
