Latest: S2cgm
Overall: 17178
Online Now [82]:
Visitors: 80
Bots: 2
Today: 45426
Total: 136367239
Forums › The Car › 206 Talk › Info Needed
Info Needed
AshH
PostPosted: Sat Aug 27, 2011 8:52 am Up
Afew thing I need help on;
1. What is the Bore Size of a 1.4 8v exhuast, looing to just put a cheap Universal Back Box on and need Bore size :/
2. Iv brought an aftermarket Bonnet Vent, but having trouble getting the old 1 off. The pins holding it in are that stiff its breaking away, 1 has snaaped Sad
The help i need with this is the easiest way to get em out without snapping em, and how to get the b***hard out that has snapped??
Thanks, Ash.
Team - 180
Team - ATM!!!
ukskater01
PostPosted: Sat Aug 27, 2011 9:00 am Up
Not sure about the bore size, sorry. For the vent I used a small flat head to prise the middle of the mushroom clip out, then used needle nose pliers to pull it out. I saw someone say ram a flat head through them if there stuck, not sure if it works though
Bassline_Toad
PostPosted: Sat Aug 27, 2011 9:01 am Up
screwdriver undeneath the lip and pull, normally works. If they break, its only cause they're old. Solution - Go to Peugeot and buy some more, only a few pence I imagine, then cause they're new, it shouldn't happen again Smile
AshH
PostPosted: Sat Aug 27, 2011 9:03 am Up
So in other words, grip, and pull. If they brake us my old sayin yeaa?
"If it don't fit, force it. If it brakes, it needed changing anyways"
Thanks guys, ill go rip the f**ka aprt now lol
Team - 180
Team - ATM!!!
craigdmjv
PostPosted: Sat Aug 27, 2011 9:11 am Up
i always use a flat head screwdriver t get the head up a little then use a fork to pull the out as the fit perfectly between the fork bits lol
mtempsch
PostPosted: Sat Aug 27, 2011 9:20 am Up
I've heard of forks being used to lever up the center pin, one tine each side of the stem - personally I use a thin knife coming in from the side, pushing the edge in between the base part and the head of the center piece, twist a bit to force the pin up a bit. Move knife to other side and twist there, repeat until you can grab the center piece with fingers or a pair of pliers/pincers and pull out. Then the same procedure for the bigger, expanding, piece if it didn't come out along with the center piece.
If you've already snapped of the head or stem of the first piece then I think the best bet is to use a nail/punch or something like that to push the remaining piece through (IIRC the outer/bigger piece's center hole goes all the way through. If I'm wrong in that then it's either careful use of a drill bit of suitable diameter to drill out the remaining stem - or applying knife/pincers/pliers with more force and destroy the rivet completely).
New ones shouldn't be very much from Peugeot.
Silvermetallic 2004 206 RC
PostPosted: Sat Aug 27, 2011 10:15 am Up
The replacement parts are 781324 @36 pence
PostPosted: Sat Aug 27, 2011 4:57 pm Up
Just a note on the exhaust, if you are planning on fitting a universal backbox even with the correct bore size it still won't fit well / at all will need welding best bet is to get a straight fit one to be honest. You probably already know this but just saying incase you don't.
vanman_foci
PostPosted: Sun Aug 28, 2011 3:00 am Up
2" is bore size
AshH
PostPosted: Sun Aug 28, 2011 4:58 am Up
Yeah i've got a guy who does all my metal work, he said he will weld it for me for fak all so no probz there. Thanks guys.
Team - 180
Team - ATM!!!
craigdmjv
PostPosted: Sun Aug 28, 2011 5:33 am Up
you making it a 180 rep then
