Latest: evert
Overall: 17112
Online Now [33]:
Visitors: 31
Members: 1
Today: 6799
Total: 93740167
Forums › The Car › 206 Problems › Rear fog lamp bulb
Rear fog lamp bulb
jwoo06
PostPosted: Sat Oct 15, 2011 4:20 pm Up
Good evening everyone, how are you?
Whilst I was doing a light check (what with Winter coming) I noticed the rear fog light was not working. I do have front fog lights and you have to push the end of the indicator stalk round twice for all the fog lights to work, however the rear fog light does not seem to be working.
How can I change the bulb and is it hard to do?
Thank You so much Smile
Original and Mint 2005 Peugeot 206 1.4
mtempsch
PostPosted: Sat Oct 15, 2011 4:37 pm Up
Easy - reach up behind the plastic, untwist the bulb holder (bayonet fit to the lamp housing). Bulb (21W Ba15s) is normal bayonet fit in socket.
Or first depress the metal spring on the side that secures the housing to the bumper and pull it [the housing] out towards the rear(not very long wires though so don't be too enthusiastic about it).
Silvermetallic 2004 206 RC
jwoo06
PostPosted: Sat Oct 15, 2011 4:43 pm Up
So reach up behind the bumper, twist the bulb holder out and put a new one in Smile Thankyou so much Smile
Majid
PostPosted: Sun May 12, 2013 5:14 am Up
onHi my rear fog light doesn't work iv replaced it with new bulb. It's a 2003 1.6sxi do these contain a fuse and If so where and what number?
Cheers
Peugeot 206, 1.6, 16 valve
2003
PostPosted: Sun May 12, 2013 5:26 am Up
Cheers
Fuse 6 in the engine bay, 15 amp.
Are you getting the tell tale on the dash lighting up?
Did the foglamp work before you swapped it for a clear one?
PostPosted: Sun May 12, 2013 11:29 am Up
Buy a Haynes manual. Not perfect but all the simple jobs (and harder ones) are covered in excellent detail and include things like fuse, locations and numbers of which do what.
Majid
PostPosted: Mon May 13, 2013 12:53 am Up
I don't know if the old lamp was Woking. By the way ain't fuse number 6 in engine bay for front fog lights only?
PostPosted: Mon May 13, 2013 3:19 am Up
Yes it is sorry, only glanced at the wiring diagram. No fuse for the rear. The switch is part of the VAN system which then runs into the BSI and to the fog lamp.
Are you getting the tell tale on the dash?
Take the bulb out, start the engine, turn the dipped beam headlamps on, turn the foglamp switch twice to turn the rear fog on, and check you're getting 12volt at the connector using a multimeter. Also do a continuity check on the earth to make sure that it's connected properly.
Majid
PostPosted: Mon May 13, 2013 5:37 am Up
Cheers macca and other users for your help.
Update
Iv traced from rear fog light bunch of wires to the boot. The bunch carries on through the car. There's another bunch of wires coming from the car one it's got a blue plug and nothing's attached to it. Could this be the problem?
New bulb and fog sign displayed on dash
2003
Sim
PostPosted: Mon May 13, 2013 6:32 am Up
Online
You get green fog sign even on first position - that's for front lamps.
Second turn shows yellow circle with black fog light facing opposite dir - that's for the rear fog light. Is that coming up?
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
Majid
PostPosted: Mon May 13, 2013 7:41 am Up
Yeah it is
2003
mtempsch
PostPosted: Mon May 13, 2013 8:31 am Up
Majid wrote:
Yeah it is
Then the fuses should be OK - IIRC, from the fuse goes 2 wires in parallel, one to the cluster indicator and one to the light in the rear.
As macca said, multimeter to the bulb holder and check for +12 on the centre, and continuity to ground on the ring.
Are the terminals clean? Does the centre contact in the bulb holder sit high enough to provide good contact to the bulb?
And a sanity check - does the new bulb actually work? If you haven't - test it - w/ meter, piece of wire and the battery terminals, or put it in a known working spot (brake light/indicator).
PostPosted: Mon May 13, 2013 8:42 am Up
Don't try this as they are twin filament connectors for the brake/tail light and you are likely to knacker something else up.
Indicator or reversing connector should be fine though.
mtempsch
PostPosted: Mon May 13, 2013 8:54 am Up
Dang, sorry about that one!
I've got LED rears since pretty much day one, so I've never had to change a rear/brake bulb on the 206...
