Latest: evert
Overall: 17112
Online Now [54]:
Visitors: 53
Today: 12317
Total: 93802433
Forums › The Car › 206 Problems › Car not starting
Car not starting
austin316
PostPosted: Wed Oct 26, 2011 12:33 pm Up
Hi guys, my car isn't starting.. I switched my keys over today (to a flip one) and had to keep locking/unlocking the car to get the positioning of the keys correct. I went out this evening, and car wouldnt start. I hooked up the other car (1.4 fiesta if thsi helps) and was revving for about 15-20 mins, and still car wouldnt start, any help pls?
5 door
1.1 8v
04 reg
Dutch-HDi
PostPosted: Wed Oct 26, 2011 12:34 pm Up
you put in the transponder ?
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
austin316
PostPosted: Wed Oct 26, 2011 12:36 pm Up
Yup, and have also tried the spare key I have, and both have the same effect on the car.
5 door
1.1 8v
04 reg
PostPosted: Wed Oct 26, 2011 12:38 pm Up
Is it turning over?
shell-vt
PostPosted: Wed Oct 26, 2011 12:43 pm Up
Trade Rating: +46
possable immobiliser ..
york 16,3
austin316
Yes, is turning over, but the turning overr didnt get any 'stronger' throughout me trying to jump start it.
5 door
1.1 8v
04 reg
austin316
PostPosted: Wed Oct 26, 2011 12:45 pm Up
Oh, and i should add that it did start when i had put the transponder etc in the new key, before i started messing about with the buttons in the right position
5 door
1.1 8v
04 reg
PostPosted: Wed Oct 26, 2011 12:46 pm Up
Immobilser fault.
Check the chip
Spare Key
Fuel cut off
Aerial
Double relay
Attempt a code read to confirm
Check wiring
New/Replacement BSI or ECU
austin316
PostPosted: Wed Oct 26, 2011 12:47 pm Up
Ohh dam lol... Can i just ask what could have caused this?
5 door
1.1 8v
04 reg
PostPosted: Wed Oct 26, 2011 12:49 pm Up
What year car is it?
Defiantly checked the chip is in there and tried the spare key?
Tried bumping it?
austin316
PostPosted: Wed Oct 26, 2011 12:54 pm Up
2004 (53 plate) and yup, car started earlie with that key, and also tried spare.. and not tried bumping as of yet
, could this work?
5 door
1.1 8v
04 reg
PostPosted: Wed Oct 26, 2011 12:56 pm Up
Shouldn't jump start a multiplexed car.
Try soft booting the BSI
If it bumps, then it rules out a IMMO fault.
austin316
PostPosted: Wed Oct 26, 2011 12:59 pm Up
Oops, sry, whats soft booting the BSI?
5 door
1.1 8v
04 reg
PostPosted: Wed Oct 26, 2011 1:01 pm Up
206info.co.uk/Forums/v...=1675.html
austin316
PostPosted: Wed Oct 26, 2011 1:28 pm Up
have just tried the soft boot method... The clock lights and everything comes on as normal inside the car, the sidelights came on, but only after i put the ignition on. When I tried starting the car, the engine was making a kind of whirring noise, not sure if this is the engine turning over?
5 door
1.1 8v
04 reg
