Online Now [592]:
Visitors: 592
Today: 203717
Total: 150270885
Forums › The Car › 206 Problems › squeal on startup
squeal on startup
Ajo123
PostPosted: Fri Jan 20, 2012 12:39 pm Up
My engine has begun making a high squeaking sound for approx 20-30 seconds at a time. this usually happens when i start it up from cold but now and then i hear it ever so slightly. to my limited knowledge this sounds like a fan belt? Iv only had the car a couple of weeks and its under warranty, id just like to able to explain it to them if it doesnt do it when i take it back!
It started doing this a few days after i got it home very slightly, but its definately getting louder and longer
Cheers
206 Sport 1.4 16v
A18NHH
PostPosted: Fri Jan 20, 2012 12:47 pm Up
When i had a very similar problem it was thr fan belt/aux belt and few other parts linked to it...
Wahoo!
AshH
PostPosted: Fri Jan 20, 2012 1:00 pm Up
Aux belt. If it gets worse defo!!
Team - 180
Team - ATM!!!
Razor34
PostPosted: Fri Jan 20, 2012 1:22 pm Up
Definitely aux belt replacement time
Ray
Antknee
PostPosted: Fri Jan 20, 2012 1:23 pm Up
Sort it sooner rather than later if it fails or one of the pulleys fail it can get stuck in the cambelt and take out the engine
Ajo123
PostPosted: Fri Jan 20, 2012 2:17 pm Up
excellent cheers, ddidnt think it was that serious!
206 Sport 1.4 16v
Antknee
PostPosted: Fri Jan 20, 2012 2:36 pm Up
Its probably not but better to get it looked at just incase
PostPosted: Fri Jan 20, 2012 2:56 pm Up
it happens before.
Ajo123
PostPosted: Sun Jan 22, 2012 5:20 pm Up
Further to this, I was looking my car over today and noticed there is no heatshield/cover on the underside of my bonnet. Is there supposed to be one here, and if so, does it cover the two vents in the bonnet of every 206?
Im thinkning this may be a cause of the problem if moisture is getting into my engine bay, as the noise was noticably worse during this crappy weather the last week or so
206 Sport 1.4 16v
PostPosted: Mon Jan 23, 2012 10:28 am Up
Not all 206's have the under bonnet sound proofing fitted.
