Online Now [111]:
Visitors: 110
Today: 16856
Total: 139091589
Forums › The Car › 206 Problems › ELM327 will not connect
PostPosted: Thu Jan 26, 2012 4:03 pm Up
Yes the lead is a cheap Chinese clone but it will connect to my wife's Alfa 159 (9/10 times) and to my son's Alfa 147 (8/10 times.) However it will not connect to my daughter's 1.4 8V 206 "W" reg.
I have set the bit rate and port number correctly (it wouldn't connect to the other cars if that was wrong) and also unplugged and reconnected to the car about 15 times hoping that would clean any dirty pins.
I am now lost for a way forward.
Is it just that the Peugeot is more fussy of cloned leads than the Alfa or should I be looking for damaged plug or disconnected wires on the car interface.
EasyOBDII will get past the "Vehicle data bus" but fails at the "vehicle rsponce."
ScanMaster-ELM will find the port, report the battery voltage but reports "protocol unknown" and then reports "please wait for connection" then shows "no connection to ECU"
OBD2Spy gets to "M1: requesting supported PIDs" and then gives lots of "Port Closed" messages before a popup box with a runtime error.
PostPosted: Thu Jan 26, 2012 4:17 pm Up
It's not EOBD that's why
PostPosted: Thu Jan 26, 2012 4:21 pm Up
Lee: I thought that the engine ECU was OBD2. Shouldn't OBD2Spy or ScanMaster have connected? My wife's 159 is definitely OBD2 and that connects with both ScanMaster and OBD2Spy.
PostPosted: Thu Jan 26, 2012 4:26 pm Up
after 2001 for petrol and 2004 for diesel.
W reg is 2000; won't support OBD II
PostPosted: Thu Jan 26, 2012 4:32 pm Up
OBDII is American
EOBD is European
It's not EOBD
PostPosted: Thu Jan 26, 2012 4:33 pm Up
Does this make it PP only then? It does have an OBD ELM shaped connector. Is there other software that will work with the ELM327. My Alfas will connect with both KKL and ELM using different software.
PostPosted: Thu Jan 26, 2012 4:35 pm Up
Actia based diag only
PostPosted: Thu Jan 26, 2012 4:37 pm Up
Actia? Never heard of that one. What cable and where do I get the software please.
www.actiamuller.com/uk...t-vehicles
Paid £1499 for mine.
Actia are who make the Evo cable
PostPosted: Thu Jan 26, 2012 4:43 pm Up
Ouch. Well I'm not paying that much just to find out if it is gauge, sensor or thermostat that is the cause of 70 degree water temp reading.
Especially as the heater gets really hot and the dash temp gauge needle is rock solid on 70 even when stationary for 30 mins. That must be either gauge or sensor. My money is now on sensor.
If it's sending a low temp signal then it's probably also running a bit rich (although plugs were a pretty good colour) so I will change the sensor.
PostPosted: Thu Jan 26, 2012 4:45 pm Up
Mines runs at 70. Has done for all 4 years I've owned it, and there is nothing wrong.
PostPosted: Thu Jan 26, 2012 4:48 pm Up
I thought only Alfas had electrical gremlins!
PostPosted: Thu Jan 26, 2012 4:50 pm Up
Yours is diesel & they run cooler then petrols Wink
PostPosted: Thu Jan 26, 2012 4:58 pm Up
I know they do. Didn't know his was petrol. Just knew it wasn't EOBD from the title.
PostPosted: Thu Jan 26, 2012 4:59 pm Up
Run K-line from ELM direct to ECU
