Posted: Mon Jan 30, 2012 10:04 am |
Im trying to remove mirror so i can get to the temp sensor but not sure what is holding it on? Tried to get a screwdriver behind it but dont want to break anything?
Is there a knack to it or id it just get a bit rough with it?
Posted: Mon Jan 30, 2012 10:20 am |
Don't get rough with it! Try and heat it up first to stop it cracking with a hairdryer.
I use a small pick set at work, the best one I use has a hook at the end.
| You never really learn to swear until you learn to drive | |
Posted: Mon Jan 30, 2012 11:58 am |
Got it off but couldnt see anything wrong with the wires to the outside temp sender?
Better follow the wires back to see if there is a break somewhere because i know its not 39 degrees today.
Posted: Mon Jan 30, 2012 1:06 pm |
Couldn't the sensor be f"cked not the wiring?
Posted: Mon Jan 30, 2012 1:14 pm |
Point the mirror down and towards the car, then you can easily flick off the retaining pins...piece of p**s
The ballache is putting it back on.
Posted: Mon Jan 30, 2012 1:51 pm |
| brad-morris wrote: |
| Couldn't the sensor be f"cked not the wiring? |
Could be the sensor,are they expensive?
