Posted: Mon Feb 06, 2012 8:28 am |
Hi iv got a 1999 gti 137 iv noticed that inside the cam pulley closest to the bulk head there is a metal insert sat inside that can be removed could someone tell me what its for?
| IF IT BREAKS,IT BREAKS,ITS FRENCH! | |
Posted: Mon Feb 06, 2012 9:28 am |
Like a bolt? Are there 3 of them?
Posted: Mon Feb 06, 2012 9:40 am |
No its like a metal disc it sits perfectly inside the
Pulley but its not bolted or nothing u can just take it out lol i thought i may act as a weight or something i dont no =\
Posted: Mon Feb 06, 2012 9:41 am |
Do you have a picture?
Posted: Mon Feb 06, 2012 10:01 am |
Not just yet in work at the min il post 1 asap tho
Posted: Mon Feb 06, 2012 10:07 am |
It could be a balance weight so it runs true, just like a wheel weight. Strange how its not fixed though.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
Posted: Mon Feb 06, 2012 12:08 pm |
its called a thrust washer its meant to be there
Posted: Mon Feb 06, 2012 12:53 pm |
Posted: Mon Feb 06, 2012 12:55 pm |
| rttam wrote: |
its called a thrust washer its meant to be there  |
Ok cheers bud i best put it back in now then :L
