Forums › The Car › 206 Problems › 206 Rear Caliper Problem |
Posted: Mon Feb 27, 2012 6:04 am |
Hi All,
Ive got a 206 Gti HDI 1.6 with rear calipers that I assume are sticking on.
Its worse when Ive been parked up over night and they get better when driving.
And the handbrake is poor at best when I park up.
Anyone else had this problem?
Any advice would be great.
Cheers in advance
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Mon Feb 27, 2012 7:24 am |
Just strip them down, clean the pads where they touch the caliper, wind the pistons back in and see if all is well. Check the handbrake cable is free too.
