Posted: Sun Feb 17, 2013 2:36 am |
I was referring to southwestchaps comment about the PAS pump being in the way.
Posted: Sun Feb 17, 2013 3:12 am |
Yea ive beening looking into it and seeing what the best route to use for the PAS.
Benefit is that you could use the IC setup from a 1.6hdi 206 to keep OEM.
Posted: Sun Feb 17, 2013 3:00 pm |
I guess i could work if i brought a barrel cooler. Then put it across the engine.
Posted: Mon Feb 18, 2013 4:51 am |
That's the way I've been envisioning it. The smallest AVT Barrel chargecooler should fit, but bending the pipes could be an issue. I'll have to make cardboard model to see how it fits. A real bonus would be if it fits under the OEM engine cover to make it look completely stock.
Posted: Tue Feb 19, 2013 2:01 pm |
Just got my wheels back from powder coating, never been so happy. Cant wait to get them fitted !!!!!!!
Posted: Tue Feb 19, 2013 6:14 pm |
Very very nice What colour are theses and what size? Looking good tho :]
Posted: Wed Feb 20, 2013 4:19 am |
They are 16/205/... from a 307 with 195/45 tyres on them.
Colour is light anthracite, just waiting on the spacers so they don't rub on the struts then they will be on !!!
Posted: Wed Feb 20, 2013 8:55 am |
Brilliant what size spacers you going for?
Are you or have you lowered the car?
Posted: Wed Feb 20, 2013 3:31 pm |
Got 20mm spacers hopefully turn up tomorrow. The GTI axle i brought is lowered i think, but im going to lower the front on 35mm springs then refurbish the rear axle/set it to an appropriate height.
Posted: Wed Feb 20, 2013 6:29 pm |
Sounds like a plan mate :] I went to IM axle to have mine refurbed and they were brilliant
let me no how you get on with the 20 mm spacers as i want some but dont no how much to go by, dont want no scrubbing :] Nice updates mate :] Keep it up :]
Posted: Thu Feb 21, 2013 4:20 am |
Yeah hopefully the spacers will turn up today as im going to be sat by the door waiting
Iv watched enough videos and think i should be fine refurbishing the axle if not i know i guy which replaces the bearings so ill take it down to him.
Posted: Fri Apr 05, 2013 1:46 pm |
Haven't updated for a while as not much as gone on due to me being skint. Wheels are fitted and i am going to refurbish the axle some time in the week when i get a couple of free days.
These pictures are with 20mm spacers all round, took the 20mm off of the front but left them on the back.
Thinking of lifting the back up when i change the bearings, as the beam i brought is fairly low.
Posted: Tue Apr 16, 2013 4:03 am |
Refurbed the axle but dint take any decent pictures as I was fairly busy all day. So much nicer to have the back end not creaking every time someone gets in the back.
Posted: Tue Apr 16, 2013 9:13 am |
Trade Rating: +13
How's Steve getting on with the 95bhp map?
Posted: Tue Apr 16, 2013 10:00 am |
All is well, booked in for the rollers on Saturday afternoon.
