Latest: evert
Overall: 17112
Online Now [40]:
Visitors: 39
Today: 10991
Total: 93774619
Forums › The Car › Solved 206 Problems › pulling left when accelerating
Go to page 1, 2, 3, 4, 5, 6, 7, 8  Next
Sim
PostPosted: Tue May 07, 2013 7:47 am Up
tl;dr: http://poll.fm/48ck9
SUMMARY:
PROBLEM:
Quite likely - wishbones (that was my case, first time re-fitted brand new odd ones (passenger side rear mount bush was different than driver's side), that's why this thread is so lengthy)
SYMPTOMS:
Car pulls to the left when accelerating.
DANGER:
In such case, driving straight is compensated by turning steering wheel to the right, so when no longer accelerating, it causes car to throw itself opposite (think going into neutral, changing gears, ...)
Car wanders more when at high speeds - increasing instability Sad
REMEDIES, most-likely first, take one at a time and take time between each:
  • Check tyre pressure, wear and size
  • Replace wishbones if odd/worn (I got brand new but ODD wishbones replaced, that's how this story stretched so long Sad -- one had front bush, the other had balljoint instead..)
  • Check brakes for binding
  • Inspect front and rear suspension components for wear/play
  • Do computerised 4-wheel alignment, obtain printouts
  • Inspect steering wheel column for wear/play
  • Presence of non-factory wheels (now running 15" alloys, will try to swap back to factory 14")
  • Inspect wheel hub for play/wear
  • Thorough inspection of inner steering joint (haven't done myself yet)
  • Inspect shock absorbers for being unevenly worn/gone (about to try myself)
  • Take it to the MOT station (haven't tried myself yet)
  • Differential going (inside gearbox)
    LESS CREDIBLE CAUSES:
  • Driveshaft wear
  • Gearbox mount (under battery)
  • Drop-links/anti-roll bar?
  • Power steering?
  • Engine mounts going?
[END OF SUMMARY]
Hello fellows,
Might not be able to garage her in next couple of weeks, how urgent is this:
A month or so ago, all of a sudden steering wheel went off-centered by ~5minutes to the left.
Since then the car pulls to the left (of course), but mostly noticed when in neutral or low gear/speeds.
However, when applying more torque, and/or at speeds of ~60MPH, the steering wheel straightens itself, and the car drives fine, as long as the foot is on the accelerator!
I feel that wheel "wants" to steer bit to left or right depending if I accelerate or decelerate.
Also, a bit of play is felt in the steering wheel, if that's anyhow related.
Was inspecting brakes on Sunday, swapped front wheels together, same issue - so tyre pressure/offcentered wheels ruled out.
Wheel tracking/alignment was done 12 weeks ago.
Someone suggested an inside tie rod end bearing going, but I guess checking under those gaiters is not a DIY job..
What do you think?
Many cheers,
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Tue May 07, 2013 9:30 am Up
Your tracking is way - way out.
The fact it was done 12 weeks ago unfortunately means that either it wasn't done properly (99% as usual), and/or it's gone again due to another problem with the setup which wasn't addressed beforehand.
It could also be the plastic damper-piston in the steering rack which takes-up the free-play, which you seem to describe.
Do not continue driving the vehicle as from the way you describe it, you will crash.
It's not just the pulling to the side being the problem. The way it is now it affects center-return of the steering-wheel, and you will have assymetric turning radius so it's not stable in cornering and emergency situations.
Sorry to appear alarmist but better safe than sorry.
Sim
PostPosted: Tue May 07, 2013 9:36 am Up
Shocked
Smile Should I first wheel-align, or just take it to the local garage ?
It is cornering perfectly fine, and it's not getting worse since the off-center wheel appeared couple of months ago.
Are things going to get worse with time? Not that I'm not servicing it immediately, I'm just curious.
Car had a crash into a back of another car in Octover 2012 at about ~15MPH. Only front (lights smashed, radiator pushed), no damage to engine or geometry.
EV
GTC VXR (sold)
PostPosted: Tue May 07, 2013 9:38 am Up
This is the thing, I always think of this issue as deadly important (like brakes etc) so definately I would definately take it to the garage and tell them everything. Smile
PostPosted: Tue May 07, 2013 9:39 am Up
sledge wrote:
8O
It is cornering perfectly fine,.
and it not deteriorating since the off-center wheel appeared.
No, it isn't. Smile
Sim
PostPosted: Tue May 07, 2013 9:41 am Up
Ok, you got me, not 100% fine Wink , I get oversteer sometimes, but only when heavy cornering, e.g. making a u-turn.
Had this since months, never paid too much attention, nor rootcausing to the latest symptoms surely either
EV
GTC VXR (sold)
PostPosted: Tue May 07, 2013 9:46 am Up
Try this, take a sharpish corner one way and see how 'hard' the steering wheel feels and then do the same the other way.
It is bound to feel and turn slightly differently, so the point of 'loss of control of the vehicle' in some situations is too close for comfort.
Purely as a matter of interest, how much thread is showing on each track-rod end.
Oh, and obviously DO NOT attempt to adjust them yourself - not even a tiny-bit. Wink
Sim
PostPosted: Tue May 07, 2013 10:05 am Up
Ok, just tried turning test in the carpark - I couldn't feel the difference. Maybe low speed did not permit to.. (or my brain already compensates the missing bit :))
Track rod ends look as follows (which thread did you have in mind?):
No, will not fiddle with those myself Smile Cheers so far so much!
EV
GTC VXR (sold)
PostPosted: Tue May 07, 2013 10:11 am Up
It's not shown on those pics.
It's the one between the locking nut of the track rod arms and the amount of thread showing on the rod-ends as it where. This is just as a matter of interest.
It could be many things contributing to your issue ofcourse, but it will feel and drive a lot nicer if you sort it.
PostPosted: Wed May 08, 2013 4:49 pm Up
With the 206 this could be rear axle not just limited to front so get full 4 wheel alignment done at a reputable location. Tell them to do a full check for wear before any adjustments are made. In fact a good mechanic should be trained to check everything first before adjusting anything and should refuse to set the tracking until a worn component is rectified.
The reason I suggest 4 wheel alignment is that while the rear is not adjustable 4 wheel alignment will check where the rear wheels are pointing and if there is a problem there. Also 4 wheel alignment equipment is more sensitive than the older cheaper front tracking kit that a lot of garages are still using and less susceptible to operator error or corner cutting.
You should get a paper print out from 4 wheel kit so make sure you get your print as that will show you what has been achieved and there is no reason why a patient operator shouldn't get your front toe (the only adjustable setting) spot on.
Sim
PostPosted: Wed May 08, 2013 5:04 pm Up
Thank you for tips! My friend mechanic just inspected everything, even drive with me around to convince, because he saw nothing visually.. Apart from worn front tires. He then balanced all 4 wheels -- no major errors found.
He then swapped over front wheels to the back axle, and put nice not worn ones to the front. I think the problem is gone! I'll confirm tomorrow after commute.
I Will tell you done horror stories from wheel tracking/alignment garages tomorrow.. Cheers!
EV
GTC VXR (sold)
PostPosted: Wed May 08, 2013 8:52 pm Up
How much thread is visible on each of the track-rod ends (in mm) between the locking nut and where the threads stop?
Sim
PostPosted: Thu May 09, 2013 5:01 am Up
News after this morning commute: now the car is slightly pulling to the right instead (pulled to left previously).
I was happy to see the steering wheel way more centred, and it does not want to "escape" when accelerating/decelerating/going in neutral.
But this morning on a motorway at about ~60MPH when applied accelerator pedal, car starts to pull to the left significantly more. Worrying bit is that the steering wheel stays in place! So there is a play in the system. (my commute is not on a motorway, I went on it just briefly, so no worries there Smile )
My next stop: full wheel tracking and alignment. Because the mechanic inspected everything yesterday, the visible part of wheel column when car is lifted, inner parts of track rod ends etc - could not see any play or movement or any other suspiciousness Sad
I will measure that in mm, V9977, but for now here are the images (took them for you yesterday when car was elevated Smile ), I counted about 7 and 7.5 visible thread loops respectivelly:
Driver side:
Passenger side:
EV
GTC VXR (sold)
harvey
PostPosted: Thu May 09, 2013 6:32 am Up
i had the same problems i and replaced both wishbones problem solved
harv
Sim
PostPosted: Thu May 09, 2013 7:58 am Up
Yes, mechanic said that driver side wishbone is going, but not majorly, and should not be the main cause of these symptoms.
So firstly we got other question marks ruled out (balancing wheels and swapping them across front/back axles)
I believe my wishbones are not evenly worn (only passenger side wishbone was replaced two months ago)
So now the bet is on replacing them both? With all problems given, I believe you will all say yes.
EV
GTC VXR (sold)
Page 1 of 8
