Latest: evert
Overall: 17112
Online Now [112]:
Visitors: 110
Members: 1
Today: 6354
Total: 93739725
Forums › The Car › 206 Problems › Wheel Wobble
Wheel Wobble
Go to page 1, 2, 3  Next
Zack
PostPosted: Fri May 31, 2013 3:49 am Up
Wheels balanced 2x now all over
two new anti roll bar links done
Tracking is out could it be this?
Only shakes now and again when i go faster you can sort of feel it but there no wobble its like a dun dun dun hard to explain.
Cheers
PostPosted: Fri May 31, 2013 4:02 am Up
Driveshafts?
Zack
PostPosted: Fri May 31, 2013 4:05 am Up
How would i check them?
cheers
kwakzx7r
PostPosted: Fri May 31, 2013 4:18 am Up
Have you ever curbed it? or previous owner.Check the side walls for bulges and use your fingers if you have to, as like mine they were hard to detect by eye
Zack
PostPosted: Fri May 31, 2013 4:21 am Up
Side walls are all good they are coming to the limit on tread tho.
cheers
PostPosted: Fri May 31, 2013 4:22 am Up
Have you got the same tread pattern on both tyres?
Are the tyres marked with a rotation arrow, and if so is it pointing the right way?
Uz
PostPosted: Fri May 31, 2013 4:24 am Up
Its that s**t spacer setup your running thats causing it.
Zack
What one 20MM wow
Uz
PostPosted: Fri May 31, 2013 4:26 am Up
Zack wrote:
What one 20MM wow
no. the spacer setup that you drew on some thread. 20mm bolted to another 20mm spacer. But if youve changed it than your bearings are fooked..!
Zack
PostPosted: Fri May 31, 2013 4:29 am Up
That drawing was the rear and thats been sorted now.
On the front has always been 20MM plus there is no play in the wheel
Uz
PostPosted: Fri May 31, 2013 4:42 am Up
V9977 wrote:
Driveshafts?
How are driveshafts going to cause wheel wobble..? :S
Zack, check your discs..? might be warped.
Zack
PostPosted: Fri May 31, 2013 4:46 am Up
Uz wrote:
V9977 wrote:
Driveshafts?
Ill have a look tomorrow jack car up put it in gear take wheel off tho yea?
Cheers
Uz
PostPosted: Fri May 31, 2013 4:47 am Up
Zack wrote:
Uz wrote:
V9977 wrote:
Driveshafts?
Cheers
Just jack it up, no need to put it in gear, take wheel off, turn the wheel do the calipers pointing inward and spin the disc so you can see the edge and check if there's and side to side movement.
Zack
PostPosted: Fri May 31, 2013 4:50 am Up
Uz wrote:
Zack wrote:
Uz wrote:
V9977 wrote:
Driveshafts?
Cheers
Ok thanks Smile could it be control arms if not that?
cheers
Uz
PostPosted: Fri May 31, 2013 4:53 am Up
Zack wrote:
Uz wrote:
Zack wrote:
Uz wrote:
V9977 wrote:
Driveshafts?
Cheers
cheers
Na wouldn't cause wheel wobble. Have you checked the bolts are all done up correct lengths etc. I've had problems in the past with after market wheels and spacers where bolts have been a tad to long, you think you've tightened them up but it's that tiny bit thats causing you to have wheel wobble.
Page 1 of 3
