Latest: lio94
Overall: 17181
Online Now [329]:
Visitors: 329
Today: 32546
Total: 141282909
Forums › The Car › 206 Problems › Clock display unit , illuminated ALL the time
Deano69
PostPosted: Wed Oct 21, 2015 4:25 pm Up
Hi all Very Happy
Got a strange problem here...
Couple of days ago I locked the car up for the night and noticed the clock/stereo display still had an orange glow....
Its a 3 bulb unit and works perfectly, clock is fine, date is fine, stereo information is fine...
when you remove the keys the letters all go out , but the faint orange glow remains...
and remains...
and remains... until the battery goes nearly flat Sad
I removed the trim around it and all 3 bulbs are blazing away !!! Evil or Very Mad
Nothing with the car has been changed or messed about with recently
Would be grateful for any help or info
PostPosted: Thu Oct 22, 2015 12:51 am Up
Known BSI software bug that is still in the latest software version & unlikely to ever get fixed now.
Normally cycling the ignition key on then off again will turn off the MFD orange backlight.
It will only happen rarely, call in a multiplexed 206 quirk Wink
Deano69
PostPosted: Thu Oct 22, 2015 5:52 pm Up
would do you mean `cycling` the ignition key ???
I don't have a bicycle Sad
Sim
PostPosted: Fri Oct 23, 2015 3:57 am Up
It means turning ignition on and off and on and off and so on, until MFD finally swithces off
(I wonder if I didn't get caught by double sarcasm here Smile )
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
Deano69
PostPosted: Fri Oct 23, 2015 2:33 pm Up
thanks for clearing that up....
when you say ignition , you mean turn the key till the ignition lights come on and then all the way off and back on again.... etc , etc...
ignition lights only, you don't mean start the engine at all.... do ya ?
Sim
PostPosted: Fri Oct 23, 2015 3:02 pm Up
Don't start the engine, just all dash lights on lights off, just like karate kid Smile
EV (roadtripper)
GTC VXR (sold)
Deano69
PostPosted: Fri Oct 23, 2015 4:20 pm Up
hmmm... ok
roughly how many times, 20 ???
Sim
PostPosted: Fri Oct 23, 2015 4:24 pm Up
Until MFD orange light switches off
EV (roadtripper)
GTC VXR (sold)
Deano69
PostPosted: Fri Oct 23, 2015 4:37 pm Up
Just thought of something....
I disconnected one of the front fog lights a few days before I noticed this problem.
I haven't reconnected it yet... would that cause the problem ?
surely not Sad
mtempsch
PostPosted: Sat Oct 24, 2015 5:55 am Up
surely not Sad
Unless you've got loose, bare, wires tucked somewhere they shouldn't be, I don't see how it could.
The fog light are powered through a relay (see diagram 3 here), unplugging the bulb (just like a broken bulb) makes no difference to the car's 'brains' as it is only connected to the relay's coil while bulb and battery go over the contacts.
Silvermetallic 2004 206 RC
Deano69
PostPosted: Sat Oct 24, 2015 8:52 am Up
No, I just disconnected the plug from the back of the foglight.
then removed the complete foglight .
no bare wires or nothing like that...
mtempsch
PostPosted: Sat Oct 24, 2015 2:19 pm Up
Shouldn't be related then.
As a general caution you could fold the wiring back and tuck the connector in somewhere less exposed than dangling behind the opening.
Deano69
PostPosted: Thu Nov 05, 2015 5:26 pm Up
Just a final update here...
A week later, after recharging the battery, the display did go off...
and stayed off , had no display at all.... Sad
Anyway, I replaced the unit with a secondhand one and all is working fine now Smile
Thanks all for your input
