Posted: Sun Nov 02, 2014 4:46 pm |
12mm multi hex if i remember right, most are 14mm multi hex (or convetional 6 point hex)
| Team Impossible Possible
Posted: Mon Dec 08, 2014 4:24 pm |
Quick update:
Well Diagbox found the running fault, P1153 - motorised throttle body.
Picked up a good 2nd hand unit cheap to fit at weekend.
Apparently its a common problem & software update also needed.
Another job for the list.
Posted: Mon Dec 08, 2014 5:19 pm |
Throttle bodies are common to fail, don't forget to learn the throttle and perform resetting of the auto adaptives.
Also did you ever update your ecu software? As ive had random fault codes when they are out of date! Or the software is playing up
Posted: Mon Dec 08, 2014 5:29 pm |
Not had software update yet, its on the list
I reset auto adaptive yesterday & low speed response is better.
Posted: Sun Jul 12, 2015 12:57 pm |
Posted: Tue Jul 21, 2015 3:53 pm |
Lol good point, need to rummage German sale websites :))
Posted: Thu Jul 23, 2015 1:45 pm |
Posted: Thu Jul 23, 2015 1:52 pm |
Hi Lee
I've seen the auto relocking setting in the BSI.
Im going to have a look on my GLX as you activated the auto / motion locking on that one & see if I can find the settings.
Both cars have the exact same equipment for door locking / security, only the BSI unit part numbers & the software versions are different.
Posted: Mon Jul 23, 2018 10:58 am |
MrBSI wrote: |
A little update as the project draws near to the end.
Software update the other week & the car runs & drives a lot better
Just came by here looking for instructions on Resetting Auto Adaptives, and discovered this line. What does a 'software update' refer to in this context please?
(For clarity, I removed the horrendous universal cone filter previous owner added to my GTi and put a standard airbox back on... and want to do a reset to get the idle a bit smoother. Hoping that an adaptive reset will help.)
Posted: Mon Jul 23, 2018 11:14 am |
The engine ecu software was updated by a Peugeot main dealer along with BSI software.
Posted: Mon Jul 23, 2018 11:17 am |
Thanks. I thought that might be the case. Mind if I ask how much that set you back?
Posted: Mon Jul 23, 2018 11:48 am |
£42 but was a small friendly Peugeot dealer & a Saturday morning job.
Posted: Mon Jul 23, 2018 3:21 pm |
And three years ago!
Posted: Tue Jul 24, 2018 8:58 am |
Haha yes. Well I can *try* my local dealer, as I've got to book the 308 GTi for its service. Is there a way I can tell if it needs an update?
