Latest: eniniex
Overall: 17113
Online Now [28]:
Visitors: 27
Today: 1227
Total: 93804226
Forums › The Car › 206 Problems › 1.4Hdi Automatic climate control blower not working
pasmat
PostPosted: Mon Dec 16, 2019 6:01 pm Up
I had the blower replaced on local car mechanic, was not faulty, told that there's no power coming to the blower fan.
I think its relay, but can't locate it, and can't find anywhere online where it should be.
Blower doesn't work on any setting on the automatic climate control. I tried locating the blower resistor, but can't find it, all guides show on manual air control only.
Did remove glove box, but can't find resistor
PostPosted: Mon Dec 16, 2019 6:16 pm Up
Climate control blower motor doesnt have a separate resistor - its built in to the blower motor.
Make sure the correct blower motor is fitted, obviously the climate control version is different to non climate control version.
What year of 206 is it as there's two completely different electrical systems used on the 206.
pasmat
PostPosted: Mon Dec 16, 2019 9:41 pm Up
Its 2006 year model. Do You know where the relay might be? I tried googling around for its location, but can't find it.
Thanks so much!
gazza82
PostPosted: Tue Dec 17, 2019 9:31 am Up
In the handbook I have the A/C fuse is no 15, 15amp, in the under dash fusebox, so I would imagine the relay is there too. It doesn't show which are which in the handbook though.
pasmat
PostPosted: Tue Dec 17, 2019 11:10 am Up
Thanks, I took a look into both fuse boxes, but if I have any idea how a relay should look like, I couldn't locate a single one. Where else could they be?
