Posted: Thu Apr 22, 2010 2:11 pm |
as the cylinder head and head gasket needs replaced id though i post up some photos of my progress removing it so far....need to get all the bits to put everything back together still.....
where have the power steering pump and exhaust manifold gone?
oh theyr on the floor....
lovely smell mix of coolant and power steering fluid..
some funk on the induction pipe :mad
and more in the rocker cover...
and now some of my later....additions...
ties holding the bumper on..
biiiig spitfire sticker
the bonnnnett
and as it currently sits in my shed...
naked
Posted: Thu Apr 22, 2010 3:16 pm |
you should cam it whilst you have it open
| Quiksilver: 1.6 16v Engine Conversion. | |
Posted: Thu Apr 22, 2010 4:20 pm |
vintageoriginal wrote: |
you should cam it whilst you have it open |
cam a 1.1....calm down.....
Posted: Thu Apr 22, 2010 4:21 pm |
nakednakeddave wrote: |
cam a 1.1....calm down..... |
Posted: Fri Apr 23, 2010 2:06 am |
sorry mate, really don't get the whole rat thing, but each to there own
Posted: Fri Apr 23, 2010 2:09 am |
Austin wrote: |
sorry mate, really don't get the whole rat thing, but each to there own |
Saves washing it i suppose!
| 2.0 hdi, Pipercross conical filter, egr removed, 50mm cat back! Chipped
Awaiting cat removal (Done ), FMIC, Coilovers 40mm Spax springs to be collected at fcs ), And a nice set of Proxes! (done ) roll on the summer!
Rip Tara... U were good wee tango wagon! gonna miss u :'(
Team: No smoke, No poke......
Team: FIREDANCE! | |
Posted: Fri Apr 23, 2010 2:32 am |
Raaaaat!
Posted: Fri Apr 23, 2010 3:44 am |
i like to was it actually....didnt for like 6 months, then gave it a mega wash n forgot how nice the colour underneath was haha
Posted: Fri Apr 23, 2010 3:53 am |
how is the head gasket coming along?? get more pics up
| No longer a 206 owner
Astra H sxi. 1.7Cdti | |
Posted: Fri Apr 23, 2010 4:57 am |
Why is the PAS pump off the car?
Posted: Fri Apr 23, 2010 5:00 am |
was followin the haynes manual, and said, got to this chapter to remove power steering pump from its mount, so did, then turned back, and i realised it didnt need to be removed, jus loosened....
but atleast it gives me an excuse for new power steering fluid
and needs a new belt..
Posted: Fri Apr 23, 2010 9:39 am |
so todays work....
heads off...
head gasket...
yeap deffo fukd...
some damage to chamber 2
and ma bits...
so now the heads off to the headshop to be heli-coiled and skimmed...
Posted: Fri Apr 23, 2010 9:44 am |
Okay what's going on there? Do you actually ever service that thing? The oil looks like it hasn't been changed for like 100k. And do you have stones running through those cylinders?? I thought the rat look was only for exterior but it looks like it's got a bit going on inside as well!!
Should look a little more like my old one did:
i826.photobucket.com/a...CN1178.jpg
(Admittedly it had a head skim but a skim wouldn't even touch any of those dents as it hardly takes any off)
Posted: Fri Apr 23, 2010 9:46 am |
was due an oil change as it was, but the coolants all murky for some reason.....and no idea whats happened in the cylinder.....
but the heads away to the headshop on monday...and the rest of the engines getting a goooood clean before it all goes back together....
Plus you got some serious mayo going on
How long has it been like that??
