Online Now [47]:
Visitors: 45
Bots: 2
Today: 37282
Total: 117223845
Forums › The Car › 206 Problems › cracked oil sump
cracked oil sump
Go to page Previous  1, 2
PostPosted: Sat Feb 12, 2011 12:30 pm Up
MrBSI wrote:
Seabook wrote:
MrBSI wrote:
Ive used JB Weld to repair many different things over the years.
The tricks are:
Key the surfaces & make sure there spotlessly clean.
Mix the JB weld correctly.
Try & press the 2 parts together then use some sort of vice / clamp / support to hold them together.
Let it fully cure.
Id have a go with the JB weld first before replacing the sump.
do you have to sand the surface to provide more contact area?
www.specsavers.co.uk/b...pointment/
Embarassed Embarassed
really need to get my eye check Laughing
00budham00
PostPosted: Sat Feb 12, 2011 1:31 pm Up
easy to take a sump off?
how long will jb weld hold for ?
thanks for your input guy n girls
PostPosted: Sat Feb 12, 2011 1:38 pm Up
Forever if applied correctly unless you attack it with a grinder or other tools.
leigh_boy
PostPosted: Sat Feb 12, 2011 2:58 pm Up
if i remeber gearbox off to change the sump u can try with out but u will fight with it.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
00budham00
PostPosted: Sat Feb 12, 2011 3:30 pm Up
yeah i noticed it was abit tight ! unlike 1.1 -.1.6 models with just 12 bolts and tin sump ... curse u gti's
00budham00
PostPosted: Sat Feb 12, 2011 4:35 pm Up
jb cold weld
Brilliant stuff when used correctly Wink
New sump is £231 Shocked
Where did you get that price?
PostPosted: Sat Feb 12, 2011 5:49 pm Up
Gearbox off the remove the sump? I find that hard to believe.
sean.r.steward
PostPosted: Fri Dec 05, 2014 6:24 am Up
just happened to me. what a c**t
gearbox off and jb weld.
if you have the knowledge to take the gearbox off and the sump you would now to replace it and use proper sealer not the cheep stuff.
Oafie
PostPosted: Fri Dec 05, 2014 1:45 pm Up
you can leave the box on, just got to make sure you don't mix up the bolts when taking it off.
there are 2 different length bolts on there.
if your going to take it off you might as well get it tig welded to be safe, cheap enough to get done
Page 2 of 2
