Posted: Mon May 02, 2011 4:08 pm |
Seabook wrote: |
how come so many people suddenly know how to speak russia? lol |
Iv been speaking to a russian girl
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Mon May 02, 2011 4:09 pm |
Well, that is, Collector 4-2-1, really helps the engine breathe
what else?
Forget about 2.0 (so far)
Posted: Mon May 02, 2011 4:11 pm |
I take it my russian is a bit poor?
4-2-1 manifold is makes more exhaust gases escape = faster
1.6 inlet lets more air in = faster
Better exhaust does as above
Pannel filter is the same
| Team Impossible Possible
Posted: Mon May 02, 2011 4:12 pm |
i206 wrote: |
Addaz wrote: |
You can buy parts over here and send to russia
What year is your 206?
As this is a big factor |
2003 (Reystayling)
send to russia? Probably very expensive, no?
p.s. Because to raise the power to 1.4 - not good idea, right?  |
i sent a door card to Brazil and that cost £134 if i remember correctly, it would probably be around the same
Addaz wrote: |
Short transmission, such as 1,3-106 Rallye Gearbox |
max speed with a box, will be 120-130 km/h?
Posted: Mon May 02, 2011 4:19 pm |
Addaz wrote: |
Pannel filter is the same |
everything is fine, meaning I understand it, is the most important
but: ''1.6 inlet lets more air in'' - dont' un'stand...
what do you say about the induction blowing?
Posted: Mon May 02, 2011 4:26 pm |
1,6 впускной коллектор имеет большую дроссельной заслонки это означает, что больше воздуха может войти в двигатель, это выглядит стандарт, который хорошо
больше дроссельной заслонки также даст вам лучше приемистость, так как позволяет это дополнительный воздух, основы Tunning:
Больше воздуха
Больше топлива
Получить выхлопные газы быстрее
1,3 коробка передач имеет короткие передаточные числа означает, что она даст вам автомобиль быстрее ускорение по сравнению с другими
Antknee wrote: |
i sent a door card to Brazil and that cost £134 if i remember correctly, it would probably be around the same |
Russia is closer
Posted: Mon May 02, 2011 4:31 pm |
Addaz wrote: |
Больше воздуха
Больше топлива
1,3 коробка передач имеет короткие передаточные числа означает, что она даст вам автомобиль быстрее ускорение по сравнению с другими |
Thank you very much, but this I know:)
rapid acceleration due to gear ratios, just give me a little top speed.
but I think about it.
Posted: Mon May 02, 2011 4:33 pm |
Maybe a turbo?
but again:
A new gearbox
A new braking system
etc.
Posted: Mon May 02, 2011 4:35 pm |
Thanks to the Forum that you do not drive me away with a stick! Nice to chat with you.
Posted: Mon May 02, 2011 5:32 pm |
i206 wrote: |
Thanks to the Forum that you do not drive me away with a stick! Nice to chat with you. |
Пожалуйста
Posted: Mon May 02, 2011 5:39 pm |
depends on what kind of power are you looking for, puting a turbo in is always good.
Posted: Mon May 02, 2011 10:36 pm |
Seabook wrote: |
depends on what kind of power are you looking for, puting a turbo in is always good. |
I'll think about it Tnx
Posted: Mon May 02, 2011 11:08 pm |
I suggest to you. Dont spend money on that engine.
You can swap 2.0 engine if you can find from russia or near country.
Otherwise my second choice for 206 chassis 1.6 16v 110 hp engine.
I think you can found that one easily from 307 or other PSA cars.
| 2005 206 RC RED
Lot's of CNC machined customs pars.  | |
