Online Now [100]:
Visitors: 100
Today: 24133
Total: 116566542
Forums › The Car › 206 Problems › Driveshaft springs?
Driveshaft springs?
Rob2859
PostPosted: Thu Sep 01, 2011 12:32 pm Up
There is a spring inside the inner boot on ether driveshaft; Do Peugeot do these separately? I am struggling to find them online.
PostPosted: Thu Sep 01, 2011 12:35 pm Up
no
Rob2859
PostPosted: Thu Sep 01, 2011 12:41 pm Up
oh dear
PostPosted: Thu Sep 01, 2011 12:44 pm Up
i got a some off ebay , came sealed in a bag with Peugeot/Citroen logo on,
it may have been a seller that referbs them or somthing i dunno, was few years ago now.
if you cant find any, alot of places take take your old driveshaft as PX.
nakednakeddave
PostPosted: Thu Sep 01, 2011 12:45 pm Up
i had a bent one in mine, so i took it out, and for some reason feels much better.......
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
nakednakeddave
KRU KREW
Rob2859
PostPosted: Thu Sep 01, 2011 1:01 pm Up
Mine is snapped. I tried to go without it and its just poped the driveshaft out of the spline on my new CV joint. I think they are f****d on both sides because when I recently changed my wishbones it was a right (insert profanities). The shafts didn't go far enough in to get the bottom ball joint on. I think the spring is stuck sideways inside on the other side like it was in the one I just took off.
PostPosted: Thu Sep 01, 2011 1:04 pm Up
get a used shaft off crappy or ebay?
the oem shaft tends to be quite reliable if the boot wasn't damaged/ changed regularly.
Rob2859
PostPosted: Thu Sep 01, 2011 1:10 pm Up
I am going to get a whole new shaft for one side. For some reason the old CV joint would not come off the shaft and the only way to get it off was to smash it off and grind the spline off. It did slightly damage the thread. However I could do with a spring for the other side but there is no point buying a whole new shaft for that side as well.
PostPosted: Thu Sep 01, 2011 1:14 pm Up
i doubt you can get a new oem shaft? think all oem shaft are re-con shaft now.
and new pattern shaft are s***
you could always ask the re-con shaft company to check if they can get you some spring; i can't see that parts on service box so i doubt you can buy them from pug dealer
Rob2859
PostPosted: Thu Sep 01, 2011 1:34 pm Up
I will try that. I might ring Pug tomorrow maybe you get one with a new boot.
Rob2859
PostPosted: Sat Sep 03, 2011 8:02 pm Up
I got a second hand shaft from a scrappy which was in pretty good condition. for the one side. Unfortunately it was a 1.4 shaft as that is all they had, I have fitted it but is it likely to cause any problems? Also I lost about half a litre of gearbox oil. It was full or near enough full before so should I still top it up or will it be fine?
PostPosted: Sun Sep 04, 2011 3:59 am Up
i don't know what car is yours.
but all MA box use the same shaft.
and no, you need to top up the gear oil; full capacity is about 1.9L so half a litre is a huge loss.
Rob2859
PostPosted: Mon Sep 05, 2011 2:19 am Up
Good point. its like 25% I suppose. Its a 1.1 sorry. The shaft is bigger I measured it. That is why the new shaft would not go into the old shafts inner joint. Meaning I had to remove the rest of the shaft from the gearbox and put the complete new shaft in.
PostPosted: Mon Sep 05, 2011 3:03 am Up
you sure your old shaft is oem shaft? i know some of the cheap shaft are thinner.
but either way it should fit the the differential
and gear oil is cheap anyway. think the total BV4 75w/80 was only 5 quid for a litre
