Online Now [55]:
Visitors: 54
Today: 25353
Total: 116712105
Forums › The Car › 206 Problems › 180 cutting out
180 cutting out
broadblaster
PostPosted: Sat Feb 18, 2012 11:57 am Up
ok my daughters 180 is cutting out but only for a split second,she says that just driveing normaly it will just suddenly cut out but the only warning lights that come on are the battrey light and the handbrake light then it just carrys on as normal.
it has done this 3/4 times now and starting to worry as it could cut out then not start when shes away from the area.
sorry to be so vauge but thats all the info she has passed on
any ideas ??????
on a back road playing
furryhobnob
PostPosted: Sat Feb 18, 2012 12:00 pm Up
Have you checked the voltage on the battery? That would be my first point of call
broadblaster
PostPosted: Sat Feb 18, 2012 12:09 pm Up
tbh no as it is starting and runing fine no signs of a failing battery this has happend over a 1 mth time scale.
broadblaster
PostPosted: Sat Feb 18, 2012 12:17 pm Up
Hmm maybe worth a look at the earth strap going by a fewe other posts ?????
any other ideas ???????
also would a dieing bsi cause this ???
PostPosted: Sat Feb 18, 2012 12:24 pm Up
wouldnt be the battery to course it to cut out when driving.
More than likely the earth strap
