Online Now [67]:
Visitors: 66
Today: 32637
Total: 116906426
Forums › The Car › 206 Talk › airbag help please
airbag help please
20619d
PostPosted: Fri Mar 09, 2012 3:36 am Up
at the moment i have a momo steering wheel on car. but i know in awhile it have to have a airbag for its mot. i have the old steering wheel in the shed but the wire and bit inside the boss that sits on airbag has broke. if i put old wheel on car and clip airbag on but not connect the wires up will there be a risk of the air just going off. dont want drive to mot center and air bag goes off if i hit a pothole. any help will be great.
PostPosted: Fri Mar 09, 2012 3:56 am Up
in your case,it would be so dangerous to do so,I recommend that you get a new one
20619d
PostPosted: Fri Mar 09, 2012 4:03 am Up
how much is the bit where the steering wheel bolt to cost as need that aswell
20619d
PostPosted: Fri Mar 09, 2012 4:09 am Up
just notice it looks like the plug on wheel is fine.
so looks like only need bit the wheel bolts to.
am i right?
is this wot i need?
www.ebay.co.uk/itm/PEU..._538wt_932
PostPosted: Mon Mar 12, 2012 1:42 pm Up
yes this is what you need to change
PostPosted: Mon Mar 12, 2012 2:15 pm Up
I have one of them that you can have for 10gbp delivered
Bummers
PostPosted: Mon Mar 12, 2012 2:53 pm Up
Air bag needed for the MOT? Never had any problem when i swapped my steering wheel for a non airbag one.
2003 206xsi 1.6 16valve
PostPosted: Mon Mar 12, 2012 2:57 pm Up
MOT rules change on the 1st of April this year & a missing airbag or the warning light not going through the correct check sequence / warning lamp missing or on all the time will be an automatic FAIL.
Lecktorious
PostPosted: Mon Mar 12, 2012 3:24 pm Up
Trade Rating: +59
How the hell has the metal surrounding the airbag terminals gotten so rusty Confused
'98 Nile Blue 306 GTi 6
PostPosted: Mon Mar 12, 2012 3:34 pm Up
20619d wrote:
is this wot i need?
Nope, your airbag is MULTIPLEXED Wink
Bummers
PostPosted: Mon Mar 12, 2012 5:50 pm Up
Learn something new every day!
Am sure a friendly mot tester would turn a blind eye to a missing airbag if you can turn the warning lamp out. In fact i bet half of them wouldn't even notice it was missing Laughing
